how big a tire can i put on
Old 10-12-2010, 11:08 PM
amtrains's Avatar
amtrains
amtrains is offline
Stage I
Default how big a tire can i put on
I have a 1992 fxstc it has the aluminum fat boy wheels i think 3.5 inches wide with a rear tire @ 130/90/16. i wanna go wider with out changing the rear sprocket and belt. what are my options 150/80/16 tire? on the stock rim or wider wheel what years will fit.
Old 11-15-2010, 12:51 PM
dodgerob2's Avatar
dodgerob2
dodgerob2 is offline
Stage II
Look at the space between your drive belt and your tire. I doubt there is much space for a larger tire without changing your rear sprocket and belt to a narrower modern belt. I'm doing the research now for my bike and am thinking a chain drive conversion is in my near future. It's not the rim that is the problem, it is the wide drive belt. I'm a dyna guy but I think early softtails are very similar in this respect.
Old 11-15-2010, 02:36 PM
95custmz's Avatar
95custmz
95custmz is offline
150 is the biggest you can go without changing the rear pulley/belt.
Old 11-15-2010, 09:35 PM
big deuce's Avatar
big deuce
big deuce is offline
Stage III
Default similar ?
I have a 2005 deuce and I would also like to go with a bigger rear tire. Anyone know how big i can go. I have a 160/17 stock. I was hoping to put a new softail rim on.
Old 11-16-2010, 02:36 AM
95custmz's Avatar
95custmz
95custmz is offline
You might be able to squeeze a 180 back there with no mods on your '05.
Old 11-16-2010, 02:38 PM
big deuce's Avatar
big deuce
Stage III
thanks for the info.
Old 11-19-2010, 05:37 PM
grbrown's Avatar
grbrown
grbrown is offline
I have a 150/80/16 in my 1990 Evo. To get it in I used a later spec narrow belt and rear pulley. I have read that a 150 will fit, if you use a narrow spacer behind the pulley. Go over to the Evo forum and take a look over there, there is a recent thread on this.
A 150 is the widest we should use on a stock 3" rim. Another thing to consider is that on my bike the tyre is dead centre, but a very close fit in the fender! A wider tyre will not go in.
Old 11-24-2010, 12:48 AM
Tech23's Avatar
Tech23
Tech23 is offline
HD offered a 150 kit for your bike. It consisted of a narrower rear pulley and belt, and the 150 series tire. It is not boatloads wider than the stock 130 but a noticeable difference. Ask a good HD parts guy, he should be able to hook you up. If the kit is no longer available he should be able to tell you what parts are necessary to make the change.
Tech23
snatchcat
03-13-2019 04:39 PM
ronjon8505
09-24-2012 10:44 PM
82ndpara
06-11-2012 07:11 AM
knuckleduster271
Wheels/Tires
05-28-2011 05:43 PM
sewerat
04-10-2008 08:29 PM
Quick Reply: how big a tire can i put on
