Frame rake
Old 10-10-2010, 10:58 PM
deepsea's Avatar
deepsea
deepsea is offline
Default Frame rake
Got a few questions. I have a 2005 1200C. I would like the front raked out to about 40 degrees. How is this done with my frame. I dont see how the angle of the goose neck can be changed the way it's all welded together. How can the down tubes be lengthened the way the front cylinder mounts to the frame with that swing arm? I have looked around, and cant find a raked frame for 04 and later sportsters.
Old 10-10-2010, 11:51 PM
dbphotos's Avatar
dbphotos
dbphotos is offline
Love the quote!
Old 10-11-2010, 07:58 AM
kahaone's Avatar
kahaone
kahaone is offline
Did you read the thread you started a few months ago about this question? Finding a raked frame is easy to do, as there are several companies out there that already build frames, and many of those will make a frame to whatever specs you ask for. Led Sled, Kansas Kustom, Twisted Chopper, Nasty Bikes, Bitterend Choppers, and a number of other commercial bike builders do frame work. Google "chopper sportster frame" and you'll get many, many companies and ideas.
As for the engine mounts, as stated in the other thread, you just need to have the welder modify them, or relocate them on the downtubes. If whoever is planning on doing the fabrication work can't figure that out....I'd find a different fab guy.
EArthur999
General Topics/Tech Tips
08-04-2020 07:44 AM
eliminator
11-16-2017 02:37 PM
bfelder
12-12-2013 05:30 PM
chicko
09-28-2009 05:18 AM
tattooedskin
06-29-2006 04:35 PM
Quick Reply: Frame rake
