front brake lever rattle
Old 10-10-2010, 10:18 PM
head's Avatar
head
head is offline
Default front brake lever rattle
ive done some searches but cant find the answer. 2006 flhri road king. my front brake lever has started to rattle pretty good at idle. never had a bike do this before. the pin and the clip are like they should be. the lever and the perch are stock items with only 18000 miles. any thing i can adjust,shim.etc to stop this?
head
Old 10-11-2010, 04:22 AM
SCSG's Avatar
SCSG
SCSG is offline
Default Rattle
I would like to know the answer too. My clutch lever rattles alittle.
Old 10-11-2010, 06:35 AM
dansflhti's Avatar
dansflhti
dansflhti is offline
The clutch lever was the noisey one on my 06 EGS.
Old 10-11-2010, 07:51 AM
streetglide44's Avatar
streetglide44
streetglide44 is offline
My brake lever was rattling too, causing brake light to flutter. Camp for controls and lever was seperated a little. Loosened and pushed together. Problem fixed. Must have happened when I changed grips.
Old 10-11-2010, 08:54 AM
Drail's Avatar
Drail
Drail is offline
Both levers do have a plastic bushing that may be worn out.
Old 10-11-2010, 08:00 PM
head's Avatar
head
head is offline
ive found that when my clutch lever rattles, i can just adjust the cable on the adjuster on the cable itself to take out some play,doesnt take much. but theis brake lever rattle is a new one on me.
head
Old 10-11-2010, 10:09 PM
Neckball's Avatar
Neckball
Neckball is offline
There is a plastic little doo-hickey on the clutch lever, reminds me of a cable clamp. I think it's called an anti rattle clip. I've replaced mine twice in 80,000 miles. You have to remove the lever to see it, held on with a small screw.
Old 10-11-2010, 10:49 PM
cbears's Avatar
cbears
cbears is offline
Good to know. Mine rattles a bit and only has 7500 miles.
Old 10-11-2010, 10:55 PM
SIU 96's Avatar
SIU 96
SIU 96 is offline
I wonder if there would be a way of preventing this wear, like say often lubricating ?
Old 10-12-2010, 12:44 AM
CroK's Avatar
CroK
CroK is offline
Mine rattles also, but it doesn't bother me...
Thought of shimming between the lever and housing with shim stock cut out like flat washer(s), maybe even a piece of thin gasket material/vinyl/nylon/neo-poly-something-plastic sheet, but haven't gotten around to it yet. You could try a C-clamp to pull the two sides together, but it would be very small amount of movement necessary. And, if you happen to bend them together too much it may just crack the housing, or cause the lever to stick randomly. Gotta be careful when you become the engineer correcting something which may well be an intentionally acceptable part of the original design...
Quick Reply: front brake lever rattle
