New Engine Codes
Old 10-10-2010, 09:56 AM
vickers1's Avatar
vickers1
vickers1 is offline
Default New Engine Codes
Yesterday I rode for about 120 miles. Had been having slow cranking problems for the past few weeks after parking it for a week or so (had to jump it off again yesterday) so I installed a new battery. I thought I felt a miss a couple of times while throttling up but otherwise the trip was uneventful.
Got home and did a code check and found these codes:
P1511 Throttle actuator control power management failure of throttle control actuator
P2101 throttle actuator control motor circuit range/performance error
I cleared the codes to make sure it wasn't battery problem related and I'll ride today to see if they come back but does anyone know where to check as to what part may have caused these codes to appear?
Old 10-10-2010, 10:51 AM
petemac's Avatar
petemac
petemac is offline
Old 10-10-2010, 11:17 AM
vickers1's Avatar
vickers1
vickers1 is offline
Originally Posted by petemac
Thanks Petemac. That info helps.
Old 10-10-2010, 12:32 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
It should give you a part number on the next push of the reset button?
Mark
Old 10-10-2010, 02:24 PM
vickers1's Avatar
vickers1
vickers1 is offline
Does it really?
Old 10-10-2010, 02:36 PM
user 8373900
It should...Push the reset button again (or wait and it will flash a PN#) after retrieving your code and it should read off a PN ______ . That is your part number.Another push of the button moves you to the next diagnostic group.
Mark
Old 10-10-2010, 05:28 PM
vickers1's Avatar
vickers1
vickers1 is offline
Ok then next question: Does anyone have access to what part # 32933-08 is?
07bagger
02-24-2014 05:58 PM
09rkpolice
02-09-2013 08:03 PM
Arizona
05-23-2012 06:43 AM
tA_GTA
07-30-2010 08:00 PM
THABULL
06-20-2008 04:12 PM
Quick Reply: New Engine Codes
