Oil additive to improve low compression?
Old 09-26-2010, 07:33 AM
2011FLHTK's Avatar
2011FLHTK
2011FLHTK is offline
Default Oil additive to improve low compression?
Has anyone found an oil additive that actually helps improve compression in a 10-year old engine?
My buddy's 2001 Ultra has low compression (60-70%) and he was told that some additives will actually improve his compression. Is that just product hype and marketing, or has anyone here actually had success with any of these products?
Old 09-26-2010, 07:48 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
We use to pour ATF down the carb with the engine running back in the day...
__________________
www.Captain-Itch.com
Old 09-26-2010, 10:00 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
Well, with all the cheap take off parts available on Ebay , even I have a set of dealer take off cyls and pistons for sale, it should be cheap enough to refresh a top end.,,
Old 09-26-2010, 11:40 PM
RandyDowdy's Avatar
RandyDowdy
RandyDowdy is offline
My dad used to pour water out of a small coca cola bottle (that was the proper amount for a V-8) and it would clean all the carbon off, seemed to make the rings reset. Did change the oil consumption, whatever it did inside did work.
Old 09-27-2010, 04:14 PM
cochon's Avatar
cochon
cochon is offline
It's hard to beat actually fixing the problem. Just saying.
Old 09-27-2010, 07:08 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Try some 60w oil or lucas stabilizer. But I have also seen quite a few take off heads & power cylinder components on ebay.
Old 09-29-2010, 05:03 PM
2011FLHTK's Avatar
2011FLHTK
Thanks guys. I'll tell him about his impending winter project.
Old 09-29-2010, 05:09 PM
bluesmanjesse's Avatar
bluesmanjesse
bluesmanjesse is offline
No disrespect but,I'm not sure that's the best advice if you would like to keep the bottom end of your engine in good working order.
Thicker oil is bad for your engine,some additives will actually make things worse. Just fix it,why not take the oppourtunity to upgrade to a little big bore action?
Old 09-29-2010, 11:08 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
I agree. But he asked about an oil fix not rebuilding. Plus if the engine is at 60% it will probably need an overhaul soon anyway and he may get a season out of it by using a heavier oil. 60w is not too heavy for a HD engine but depends where you live.
REVANGER
07-13-2017 01:20 PM
woznotwoz
07-10-2012 01:58 PM
hendo70
02-11-2009 08:23 AM
jackinthebox
12-03-2008 11:33 PM
jayemt551
10-09-2007 12:45 AM
Quick Reply: Oil additive to improve low compression?
