How Much Fork Oil
Old 09-25-2010, 06:52 AM
Brit Bob's Avatar
Brit Bob
Brit Bob is offline
Stage II
Default How Much Fork Oil
Just taken on a 2008 Fat Bob FXDF with a leaking front fork seal. Oily trouser leg to prove it. I have the seals and will be changing both soon. Can anyone confirm the specified amount of fork oil required in each leg after rebuild. Thanks for any reply. It's my first post so be gentle with me.
Old 09-25-2010, 07:18 AM
stevelonewolf's Avatar
stevelonewolf
stevelonewolf is offline
I believe it's 10.6oz per tube(dry). 9.7oz per tube(wet)
Old 09-25-2010, 06:28 PM
DaytonaPS's Avatar
DaytonaPS
DaytonaPS is offline
49mm forks, it's 26.6 oz each tube
Old 09-26-2010, 12:44 PM
Brit Bob's Avatar
Brit Bob
Brit Bob is offline
Stage II
Thanks guys. It has the 49mm forks I will go with 26.6 oz per tube.
Old 09-26-2010, 12:46 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Few oz's of overfill will give you a horribly stiff ride. Don't ask me how I know that.
Old 09-26-2010, 02:49 PM
peppi's Avatar
peppi
peppi is offline
It should be listed in the owners manual. You don't want to overfill the forks and may consider changing the fork oil weight if you feel the front end dives too much. They come with 5 wt in them and a 10 weight would do the trick nicely. Most feel the front end is too soft with the 5 wt in them.
Old 09-26-2010, 03:08 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Lighter bike, I'd stay with lighter fluid. I tried the heavier in my Heritage one season, then after chroming my sliders I put the light oil back in. Really noticed a softer ride when switching back. I didn't like feeling every imperfection in the road.
If I had a heavy fairing, it would have been a different decision.
Old 09-28-2010, 04:50 PM
peppi's Avatar
peppi
peppi is offline
Good point Ed but the next grade up is a 10 wt from the stock 5 weight. If you went to the SE oil which is a 15 wt or the off road SE oil which is a 20 wt., then I would agree with you completely.
The stock suspensions with the 5 wt are very mushy.
You may even want to mix oils to arrive at a 7.5 wt just to firm it up a bit.
Old 09-28-2010, 05:56 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Yeah, I can't say for sure which one mine was. It was supposed to be the next step up from stock, but I don't remember specifically if it was 10 or 15. It's been a while.
The good news is, it's easy enough to drain and start over, if he ends up too stiff. Experimenting can be fun.
Old 09-28-2010, 09:00 PM
peppi's Avatar
peppi
peppi is offline
Agree there with the experimenting. Tried all 3 weights in mine just to see the difference, it's very noticable when compared in the same bike in a short time.
Swain66
04-17-2013 06:13 PM
Steel Steed
07-09-2012 06:59 AM
harley_jeff
07-25-2010 10:52 PM
danike
03-21-2009 09:24 AM
papamonkey
14
11-07-2005 07:57 PM
Quick Reply: How Much Fork Oil
