What kind of engine oil and how much does it hold?
Old 09-24-2010, 11:25 AM
mclldavidson's Avatar
mclldavidson
mclldavidson is offline
Default What kind of engine oil and how much does it hold?
For a 2003 Fatboy. It was serviced last time by a shop(the first time I ha to service it when I got it) and I can't find my owners manual. What kind of oil and how much does it hold? Also, what other service should I perform, I am at 16k miles
Old 09-24-2010, 11:49 AM
hspring03's Avatar
hspring03
hspring03 is offline
The manual says it will hold 3.5..... But I only get 3 in there.
Kind? About 4000 opinions on that one.....
How many miles since the dealer serviced it?... If your not sure what they serviced, do the primary and transmission as well....
Old 09-24-2010, 01:49 PM
mclldavidson
How much oil does the primary and transmission hold?
Old 09-24-2010, 02:24 PM
98fat's Avatar
98fat
98fat is offline
Forget the specs, fill the primary up to the clutch basket (do a search on here for what that is) and the tranny up between fill and full.
Old 09-25-2010, 02:50 AM
TexFordD's Avatar
TexFordD
TexFordD is offline
Transmission; 32 oz. (0.95 liters) Engine oil; 3 quarts(tip; put enough oil in filter to soak media but not run out when installing) Primary; 32 oz. ( the basket is the clutch assembly)
I use Redline Primary oil, Aimsol 20W50 in engine with a Harley oil cooler and Bel Ray big twin in transmission.
The clutch plate 'chatter' is gone, The engine is much quieter than with the HD syn 3 at temps over 100* and the tranny shift is much more 'solid' as well as 5th gear scream being reduced.
My '08 is at 25K with no leaks or knocks.
If you change over, double dump, drain, put in new, run a 100 and drain off again to flush out old.
Get a lift.
When changing the primary and tranny get it hot, put on lift, place pans, drain plugs out and go to bed. let it drain off over night.
When reinstalling plugs use tourge wrench, don't trust the hand, those threads are very fine and will strip.
Finally get a manual because you will be adjusting the clutch cable and clutch at and between changes. Good Luck.
HossTuLL (07-07-2017)
Old 09-25-2010, 06:52 AM
tk353's Avatar
tk353
tk353 is offline
I use Bel Ray for the trans and no wine or clank and I can find neutral. I use Motor Factory® Primary Case Lube in the primary. because Amsoil has gone up so much I just switched to Mobil 1 for vtwin and it works as good. I have 58,000 miles in about 3 years and it runs great and no debris in the oil changes.
http://www.belray.com/consumer/product.fsp?pid=1338
http://www.customchrome.com/dcm/cc/view.asp?mfoil.html
Old 09-25-2010, 09:44 AM
magnum629c's Avatar
magnum629c
magnum629c is offline
texford 32oz it the trans ??? I dont have the book in front of me but what I recall the moter 3 qts.......the trans 20 to 24 ozs and the primary is 29ozs just shy of a qt
Old 09-25-2010, 09:45 AM
magnum629c's Avatar
magnum629c
Get a lift.
Old 09-25-2010, 09:50 AM
coronerrpm's Avatar
coronerrpm
coronerrpm is offline
I swear by LUCAS but the lucas that is made for HD motors. They have many types but I have used it in my drag car in the past and when I did it with the HD synthetic in the fatboy there is NO engine noise, neutral is a snap and at oil changes it looks great. I think it is something like 2 1/4 HD synthetic and 3/4 Lucas but not sure, It is on the bottle. I use it it the engine, primary and crank case. Just my 2 cents worth and there are tons of opinions on here.
Old 09-25-2010, 09:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
20w50 Motor Oil.
About 2-1/2 to 2-3/4 quarts in oil tank.
Don`t fill to top, leave about 1/2 inch space below filler neck, dipstick is useless, just eyeball the level.
Quick Reply: What kind of engine oil and how much does it hold?
