Primary Inner Bearing Failure
Old 09-22-2010, 09:45 PM
SeniorChief56's Avatar
SeniorChief56
SeniorChief56 is online now
Received 16,447 Likes on 4,734 Posts
Default Primary Inner Bearing Failure
@ 20,000 miles....mine failed...ESP/Extended Warranty covered it......
Old 09-23-2010, 01:56 PM
wideglidebob's Avatar
wideglidebob
wideglidebob is offline
stock up on them you`ll need them
Old 09-23-2010, 02:35 PM
hoethree's Avatar
hoethree
hoethree is offline
GEEZ! Whats up with this bearing failure? 20K miles is nothing! Is this something I have to look forward to? Is this a high failure item in the general Harley population of bikes?
Old 09-23-2010, 02:44 PM
Ugly Troll's Avatar
Ugly Troll
Ugly Troll is offline
On the entire Dyna line for 06, there was a known problem with the inner primary bearing. Each bike was sold (early model year) with a letter from the factory (to the original owner) acknowledging the defect. The letter states that the company would replace the bearing every 15,000 miles at NO cost to the customer. Sometime later, the factory rescinded the terms of the letter, claiming that the bearings no longer needed to be replaced. It remains an ongoing problem and we've put 4 of them in the wife's Street Bob so far (approx 40k now). There is also a problem on these bikes with the stator self destructing shortly after the inner bearing is replaced. The factory has refused to "officially" acknowledge this defect, although several people on this forum report being able to fight them and get it cover. The fix for these 2 issues is to replace the inner primary and transmission case with a newer design that included dowels/pins to keep the parts in proper alignment. People with this newer design report no further problems with the bearing or stator.
Old 09-23-2010, 07:52 PM
SeniorChief56
Tech said they are using the same bearing since 2007........I asked if this is something for me to look forward to every 15-20k miles. his response wasn't all that positive
Old 09-23-2010, 08:12 PM
schumacher's Avatar
schumacher
schumacher is offline
Old 09-23-2010, 09:48 PM
stef's Avatar
stef
stef is offline
The inner primary bearing failed on my '07 FXSTC a couple of months ago at 10K miles. Fixed on my dime, around $400. -stef
Old 09-24-2010, 06:21 AM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
So what happens when it fails?
Old 09-24-2010, 06:26 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,341 Likes on 3,277 Posts
Might be a leak, or a bad noise coming from the tranny/ rear of primary. It's located behing the clutch basket.
gsequel1
13
05-24-2023 10:03 PM
1987 FLHS
02-06-2014 09:26 AM
Oilslick
56
10-13-2009 08:47 PM
Shrug
05-22-2007 11:44 PM
dynalowride
04-30-2007 03:23 AM
Quick Reply: Primary Inner Bearing Failure
