Sponsored by: Jekill and Hyde
Rinehart Exhaust
Old 09-16-2010, 11:45 AM
Libbo's Avatar
Libbo
Libbo is offline
Default Rinehart Exhaust
Hello, I need some help, not real familiar with forums but I'm looking for some help. I have a set of true dual rinehart mufflers. Is there a way to use them on stock headers (2006 FLHX carb) are do i need to sell them and get different pipes? Thanks for any help.
Old 09-16-2010, 07:10 PM
OIF08Streetglide's Avatar
OIF08Streetglide
OIF08Streetglide is offline
Default Slip on's?
Best advice is to see if you can identify exactly which mufflers you have. Check the Rinehart website and match what you have. Once you find the match on the site it will tell you what head pipe they will fit. The other option is place one next to your system to see if the mounting brackets match up, if they look close then remove your muffler to see if the pipes are the same size. It's a couple bolts and a clamp and can be done with basic hand tools. Hope this helps.
Old 09-17-2010, 06:28 AM
Libbo's Avatar
Libbo
Libbo is offline
I have the Rinehart True Dual mufflers. They are 2", the stock exhaust is 1 3/4". So I will have to buy True Dual headers to make these work on my bike, I do not want to go with true dual, I want to stay with stock headpipes. Thanks for the help and hopefully I can sell these and get the slipons for the stock exhaust.
Old 03-05-2011, 07:13 PM
rare100thHD's Avatar
rare100thHD
rare100thHD is offline
A muffler shop may be able to make you a insert to go inside the larger rinehart insert.
scarecrow
09-02-2020 07:23 PM
Engbr
07-22-2015 06:28 PM
beefcake.
Screamin Eagle CVO Models
07-06-2012 03:19 PM
HilllBillly
06-19-2007 01:28 PM
skos
04-30-2005 09:46 AM
Quick Reply: Rinehart Exhaust
