Andrews 37H Cams
Old 09-06-2010, 08:59 PM
young n bag'n's Avatar
young n bag'n
young n bag'n is offline
Default Andrews 37H Cams
I have been looking around for a great cam and priced affordable. I have family use Andrews Cams and were very happy with the results that they produced. I been looking and been looking at the 37H cams. I was wondering if anyone has any experince with these cams and did they use the crankshaft sprocket with +4 or -4 degrees timing change.
Any input is good about any other cams also
Old 09-07-2010, 11:32 PM
thereal142's Avatar
thereal142
thereal142 is offline
I have 31's in my motor which are the same cam with all the timing events rolled a little later....I think the 37's are great for 95" or 96" motors, and the 31's are better for 103's....Here is a link to a shop that uses nothing but 31's, 37's, and 50's in ALL their street motors...
http://www.johnsonenginetechnology.com/index.html
Old 09-15-2010, 09:43 AM
young n bag'n
I got to looking and seen that andrews has a advancement sprocket that you increase or decrease timing +4 degrees or -4 degrees. what would the effects of using the sprocket do for me?
Old 09-15-2010, 12:35 PM
jaymcgil19's Avatar
jaymcgil19
jaymcgil19 is offline
Give Andrews customer support a call. They will answer any of your questions. Very friendly
Old 09-15-2010, 01:20 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
I had Andrews 26H cams in my 07 with a 96" and it ran great..Lots of pull and down in the RPM range where a bagger needs it.
Mark
Old 09-15-2010, 02:24 PM
inverse121's Avatar
inverse121
inverse121 is offline
+4 degrees brings on the power a little earlier
-4 degrees brings on the power a little later
Old 09-15-2010, 04:48 PM
nick@nite's Avatar
nick@nite
nick@nite is offline
Great bagger cam.....lots of pull call them great people.
Old 09-16-2010, 08:13 AM
young n bag'n
the one other thing i was looking to do was to port and polish the heads amd didn't know if this cam would be alright to do this with. i have been doing a lot of searching and just wanting to get the best bang for the buck with out having to do and bore kits. i know once you start you can't stop so i geuss i am also looking down the road too. thanks everyone for you inputs and info you have
Old 09-16-2010, 09:04 AM
cooper57M's Avatar
cooper57M
cooper57M is offline
The Andrews 37 cam was popular with the twin cam 88 engines. The combination recipe by a lot of tuners a few years back was to use it in a 95 cubic in engine(bored out), mill the heads to get around 9.8 to 1 compression (max), and clean up the heads (street port ). I have installed thiis on my bike in 2004. I have not seen or heard this cam being used for the TC96 engines, maybe because it lost its poularity and there are newer cams that came out since.
Hillsidecycle.com
Milwaukee Eight (M8)
01-01-2017 02:49 AM
pat1
09-10-2012 10:19 AM
AdrianVall
06-24-2008 06:31 PM
fj4069
Exhaust System Topics
03-17-2008 07:10 AM
snip0721
01-11-2008 09:38 PM
Quick Reply: Andrews 37H Cams
