Sponsored by: Jekill and Hyde
Storage - Drain gas or add stabilizer?
Old 09-04-2010, 02:22 PM
Great Gazoo's Avatar
Great Gazoo
Great Gazoo is offline
Default Storage - Drain gas or add stabilizer?
For those of us that have to put the bike to bed for extended periods. Winter up my way is pretty long...
Better to drain the tank and run it dry or add stabilizer? Someone once told me that the tank could rust if left dry?!
Old 09-04-2010, 08:15 PM
Tarponrod's Avatar
Tarponrod
Tarponrod is offline
I think if you can get ethanol free gas the fill it up and add fuel stabilizer if you can only get ethanol gas dain it and fog the tank with WD 40. I have heard that fuel stabilizers dont keep ethanol gas from separating and becoming corrosive
Old 09-04-2010, 08:17 PM
Mike T's Avatar
Mike T
Mike T is offline
It will definitely rust with empty tank.
Old 09-04-2010, 08:25 PM
jeff.georgalas's Avatar
jeff.georgalas
jeff.georgalas is offline
For years I've either added stabil or left it as is, and I've never had a problem either way. I don't know if I'm just lucky or what, but it's never been a problem for me either way. I definitely wouldn't leave the tank empty though.
Old 09-04-2010, 09:08 PM
shineybike's Avatar
shineybike
shineybike is offline
Winter in southern maine isn't quite as long as quebec but I've always used stabil without any issues. Bike is stored in an unheated barn from late november until late april or early may depending on when the snow melts. I heard recently, maybe on this forum, that the marine stabil is better then standard. I have not tried it though.
Old 09-04-2010, 11:10 PM
TCMAN's Avatar
TCMAN
TCMAN is offline
I always top off tank and add Stabil without any issues. Fog cylinders as well. Don't think I would let sit with an empty tank for extended periods.
Old 09-05-2010, 01:30 AM
nutsandbolts5212's Avatar
nutsandbolts5212
nutsandbolts5212 is offline
Top off tank and add Stabil, change fluids, hook up battery tender and wait for the next season. That's what I do and never had any probs over the years.
Old 09-05-2010, 04:33 AM
street racer's Avatar
street racer
street racer is offline
I just fill the gas tank all the way up,and change all the fluides
Old 09-05-2010, 07:02 AM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
Fill the tank all the way up, and put in blue Stabil or use Startron.
If the tank is 1/2 full or empty, the moisture will build up and could rust the tank and also will make the bike run like **** in the spring.
Steve
Old 09-05-2010, 07:10 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
never leave the tank empty,it will rust to hell.use stable or LUCAS stablizer,always change oils too,dirty oil will let the contaminates settle to the bottom of the tank/cases and will never really come out
Quick Reply: Storage - Drain gas or add stabilizer?
