P0120 - TPS1 Range Error
09-03-2010, 07:47 AM
I recently installed a Power Commander III on my 08 Ultra Classic. Seemed to run well for a while, then I go some backfires and a stall. I pulled it off and it seems to be OK. I did have a historical error code P0120 - TPS1 Range Error. Can anyone translate that into English for me?
Thanks!!!
09-03-2010, 08:19 AM
This is what it means....looks like a throttle by wire problem. If you clear the code do you still get it with the PC removed?
DTC: P0120
FAULT CONDITION: Throttle position sensor 1 range error
PRIORITY ORDER: 38
SOLUTION: 6.6 DTC P0120 ,P0122,P0123,P0220,P0222,P0223
09-03-2010, 08:54 AM
Thanks for the information. I just cleared it and will test it out today. Thanks again.'
Chrisfxdb
11
06-18-2020 11:52 PM
Jelwer57
04-18-2019 09:48 AM
dyna_rider98
General Topics/Tech Tips
07-16-2015 11:48 PM
JYG82
Electrical/Lighting/Alarm
08-27-2014 06:13 PM
PappyUSMC
05-07-2013 10:21 PM
09 ,
2010 ,
code ,
davidson ,
error ,
fix ,
harley ,
hd ,
p0120 ,
po120 ,
position ,
range ,
sensor1range ,
throttle ,
tps1 ,
trouble
