Bike shuts off while riding!!!! WTF?
Old 09-02-2010, 03:09 PM
sc413's Avatar
sc413
sc413 is offline
Angry Bike shuts off while riding!!!! WTF?
My bike shut off suddenly twice yesterday. Once freeway other on surface streets. I pulled in clutch and it started back up without issues. I recall this happened to me once a few times back, but I though I hit my ignition switch at the time. This time I am certain I didn't hit the switch unintentionally.
What gives? Any thoughts?
Old 09-02-2010, 03:11 PM
Thatzmister2u's Avatar
Thatzmister2u
Thatzmister2u is offline
Start with checking your battery cables and ensure they are tight. Common issue.
Old 09-02-2010, 03:20 PM
BlockHead96's Avatar
BlockHead96
BlockHead96 is offline
Mine did the same thing (Dyna) but wouldn't start up by just pulling in the clutch. Mine was caused by the Run Turn Brake light kit, that I believed to create a shut down mode because of the Security system.
Old 09-02-2010, 04:45 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
+1 on the battery cables, I checked the ones on my nightster last week and the battery terminals were loose. Luckily I had no issues.
Old 09-02-2010, 08:50 PM
pococj's Avatar
pococj
pococj is offline
I've had problems with my 2007 Nightster since it was new. Seems water runs down the wiring harness and eventually corrodes the fuse/relay block connections. I pull all my fuses and relays at least every other month to check them. After cleaning the bayonet contacts on the fuses and relays, shoot some dielectric grease into the sockets on the fuse/relay block. That keeps the water out for a longer time. I've had to replace the Run relay about every 6 months or so. They're a common relay and any auto parts store carries them.
Old 09-03-2010, 08:56 PM
6sick6's Avatar
6sick6
6sick6 is offline
Default Do you have a FOB on your keychain?
My battery was dying (in the FOB) a few days ago... It would flash the lights like the fob was out of range with the key in her. Sputter and try to die while riding... I replaced the battery, bike is good as new.
Old 09-03-2010, 11:20 PM
no_barcode's Avatar
no_barcode
no_barcode is offline
My Iron had lost power for a few seconds while on the highway a couple of weeks ago. Speedo suddenly dropped, engine lost power, etc.
Turned out to be a loose ground connector (on the side that connects to the frame)
Old 09-05-2010, 09:26 PM
sooie's Avatar
sooie
sooie is offline
im having the same prob. with the wifes 883 (03) you guys are saying check the grounds and or battery ? i put a new coil and new plugs and still same thing. Had to trailer the bike home last sunday and this sunday samething but made it home (we stayed close to home) so now i have the bike up on the table and was taking the nose cone off the replace the pickup. But now after reading this i dunno !! HELP dont want to throw money at it and not fix it
Old 09-05-2010, 09:31 PM
Mike T's Avatar
Mike T
Mike T is offline
Don't spend the money till you check the ground.
Old 09-06-2010, 09:02 AM
shiftharder's Avatar
shiftharder
shiftharder is offline
This exact thing happened to me on 2 occasions - I now carry a spare relay in my tool box - condensation/water rusts out the pins on the relay - this is a common problem on Sportys.
In my case the scoot would`nt start and had it towed twice - thank god for HOG insurance policy.
Quick Reply: Bike shuts off while riding!!!! WTF?
