Cam Timing Marks
Old 08-28-2010, 05:05 PM
shovelheadgreg's Avatar
shovelheadgreg
shovelheadgreg is offline
Default Cam Timing Marks
I am helping a buddy with his 2005 Sportster 1200 custom, he has one hell of a noise coming out of the lower case area. When I pulled the cover, I noticed the timing marks are way off on the front exhaust cam and now I am wondering where I can find a diagram of how the cams should be set. Supposedly it has a stage 1 Screamin Beagle kit in it. I know basically nothing about this sporty I only work on EVO and older Harleys - the ones that all HD shops don't even recognize - lol
Also he told me the "manual" said to put 80/90 wt gear oil in his primary - I thought I would die laughing - can anyone help me on this? Does the primary/chaincase oil sump back into the engine oil or tranny? If it does I think he will blow his tranny seals really fast if this oil does go into the tranny and might cause even more issues if it sumps back into the engine.
If nothing else hope someone can send me in the right direction for the cam timing mark diagram.
Thanks and I hope to hear from ya'll soon,
Shovelheadgreg
Old 08-29-2010, 11:58 AM
shovelheadgreg
When I took off the gear cover, the gear marks were off by almost 90 degrees on the front cylinder. The exhaust and intake were waaaayyyyy off, I am no sporty mechanic - dealing with only older big twins, but to me the marks should line up. When I started disassembling the 400 bolts that hold the carb on, I saw where there was alot of carbon in the carb intake - which to me means its backfiring through the carb, which means timing is off. So here I am back to the original question, does anyone know where I can download a pic of how this sporty should be set up on the gears. If the intake cam timing mark is at 3 o'clock and the exhaust timing mark is as 12 o'clock, this tells me something is wrong with the timing and the valves are not opening and closing at the right time.
PLEASE HELP,
Shovelheadgreg
Old 08-29-2010, 05:48 PM
TN Back Roads's Avatar
TN Back Roads
TN Back Roads is offline
I sent you a PM.
Old 08-30-2010, 08:56 AM
shovelheadgreg
TN Back Roads - just sent you an email from my att.net account and thanks alot!!!! Gotta order adjustable push rods, tubes/covers and gasket set this morning so this will really come in handy - if you need parts, I am an authorized dealer for a bunch of product line and will be glad to help you out for helping me out. Not trying to steal business - just saying thanks for helping.
ShovelheadGreg in Huntsville Alabama
Old 08-30-2010, 09:15 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
My Cam marks don't run in a line by just taking off the cover.
Old 08-30-2010, 09:24 AM
xFreebirdx's Avatar
xFreebirdx
Old 08-31-2010, 11:37 AM
shovelheadgreg
Sweet - and thanks to all for the assistance. Great description of how to do this! Just too many gears for us old farts...lol
shovelheadGreg
Spurlee
Ironhead
11
01-07-2018 09:09 AM
Sossbr1
EVO
09-22-2017 02:06 PM
keatingiv
07-19-2012 07:02 PM
1979Sportster
Ironhead
11-08-2009 11:43 PM
4rupert
Flathead
12-15-2008 01:31 AM
Quick Reply: Cam Timing Marks
