Sponsored by: Jekill and Hyde
Engine stumbles at 2500 RPM
Old 08-23-2010, 03:01 PM
shamrock2k's Avatar
shamrock2k
shamrock2k is offline
Stage II
Default Engine stumbles at 2500 RPM
This one has me frustrated and scratching my head. I've got your basic fuel injected '05 Rode Glide with a high flow air cleaned / Reinheart slipons, V&H Fuel Pak.
Couple of weeks ago, out of the blue this problem started. Just cruising along in any gear, as soon as the tach hits +/- 2500 RMP, the engine starts misfiring. It will do it for as long as I hold that engine speed. If I just let off the throttle a bit or roll on a little, everything smooths out and runs normally. There are no fault codes recorded. I bypassed the the FuelPak and took it for a test run and the problem is still there. I really can't say if the ignition is cutting out or the fuel cuts off. Also when I do light engine braking there seems to be some decel exhaust popping that wasn't there before. This popping occurs roughly at the same dead spot in the RPM band.
Any advice from the experts? Anyone had or heard of this before?
Old 08-24-2010, 01:17 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
Check the plugs and the gap also. For starters.
Change the fuel filter.
These are old time type issues. DoCheck the same old basics before worrying about the Electronic Engine Management.
Old 08-26-2010, 01:19 PM
streetbobcraig's Avatar
streetbobcraig
streetbobcraig is offline
Stage III
I installed a Fuelpak on my 09 Streetbob after upgrading to Sideshots and SEHB. Mine was acting crazy like that right off. I took it to the shop and had them do the Supertuner and a dyno run. They found a bent pin on the ECM connector and fixed it. I suspect I would have been fine without the 433 dollar SE Supertuner but I am glad I did it because the day I got her out of the shop she dropped an intake valve guide and blew the front cylinder. Harley is covering the whole thing. I hope to get her back soon.
Ubergeekin
10-23-2011 07:20 PM
billhd1
09-28-2011 07:48 AM
hamnhog
EVO
08-13-2008 03:36 PM
ubreal
10-13-2007 09:19 PM
ubreal
10-12-2007 10:48 AM
Quick Reply: Engine stumbles at 2500 RPM
