Front Wheel Removal - Fat Boy
Old 07-26-2010, 04:50 PM
TN Hillbilly's Avatar
TN Hillbilly
TN Hillbilly is offline
Default Front Wheel Removal - Fat Boy
Getting ready to remove the front wheel off my 95 FB to go get a new tire put on. I ran over a friggin screw. Are there any "gotchas" or anything special I need to watch out for?
Thx in advance
Old 07-26-2010, 05:31 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
Nope, pretty simple job if you have a bike jack. You need a torque wrench and torque specs for reassembly. Nice bike. What part of NE TN are you located?
Old 07-26-2010, 05:36 PM
TN Hillbilly
Thanks man. I am in Kingsport. I am a serious bike rookie but ain't scared. Don't have bike jack, nor torque wrench. Juts a flat. lol
Thanks for your reply. Guess I need to find me a torque wrench.
BTW your bike is gorgeous. I need some of those handlebars!
Old 07-26-2010, 06:12 PM
ROMPUS's Avatar
ROMPUS
ROMPUS is offline
while the wheel is off check front break pads fore wear would be a good time to replace them if they need to be.also dont apply front break with the wheel off.good luck
Old 07-26-2010, 10:33 PM
av8or's Avatar
av8or
av8or is offline
The tire and wheel are heavier than you think. Keep the jack low until you get the axle out or your bike might do a back flip off the jack. Make sure to coat the axle with anti-sieze when you put it back together.
Old 07-27-2010, 06:09 AM
Nickrc3's Avatar
Nickrc3
Nickrc3 is offline
Definitely a 'heads-up' comment from Av8or.
Old 07-27-2010, 08:56 AM
tk353's Avatar
tk353
tk353 is offline
clean the axial and coat with anti seise. be sure the bearings are good and be sure there is no slack or too snug of the center spacer between the bearings, remove the brake caliper first, mark the spacers left and right, oh and be sure to strap down the bike as it will tip to the rear when the tire is removed.
Old 07-27-2010, 11:06 AM
TN Hillbilly
Dang good info. You guys rock.
dupmaronew
04-20-2014 08:11 PM
ExDucRider
10-17-2013 12:20 PM
TN Hillbilly
07-26-2010 04:10 PM
jsfinco
Wheels/Tires
06-25-2009 09:17 AM
chunks
15
08-03-2005 11:57 PM
Quick Reply: Front Wheel Removal - Fat Boy
