Screamin' Eagle Big Bore Kit question.
Old 07-21-2010, 01:00 PM
02Flstfi's Avatar
02Flstfi
02Flstfi is offline
Default Screamin' Eagle Big Bore Kit question.
Can anyone tell me the difference between these two kits? Is the inclusion of the cam in the Stage II kit the only difference and it that what makes it "PRO"?
Both of these kits are for 01-’06 EFI Softailmodels
Screamin' Eagle Big Bore Stage I Kit for EFI Models - 95 Cubic Inches Part number 29860-04A
vs
Screamin' Eagle Pro Big Bore Stage II Kit for EFI Models - 95 Cubic Inches Part Number 29859-04A
Old 07-21-2010, 01:14 PM
kk6pg's Avatar
kk6pg
kk6pg is offline
Pro means you can run it with stock heads
Old 07-21-2010, 01:32 PM
gska3873's Avatar
gska3873
gska3873 is offline
Before dumping the money on one of those kits I would talk to a reputable tuner in your area and see what they can do for you. Not saying they are good or bad but its always good to have some other options.
Old 07-21-2010, 01:41 PM
klf33's Avatar
klf33
klf33 is offline
+1 .. oh wait.. make that + 100
Look at any graph of gains of those crazy kits, and check your riding on the street and see your RPM range, you will realize you are buying something you will never use.
Let me add, If you take some weight off your bike, you gain better HP/weight ratio and on top of it you get to 'stop' a lot better too.
Just sayin.. if you add HP, you need more break power and we ain't got much to start with.
Old 07-21-2010, 02:07 PM
beaureed445's Avatar
beaureed445
beaureed445 is offline
Just my opinion here, BUT........Power is a VERY addictive drug (ask me how I know). If you're thinking about going larger on your 88", talk to an independant shop, like GMR Performance, JD's Cycleworks, Hyperformance, Hillside, TMan Performance, etc. Their kits make WAY more power than the SE kits.....more bang for the buck. They're probably going to all start the conversation with the same questions- What's your riding style? What are you looking to gain (low end power, mid range, top end)? What's your budget. They can give you more options.
Gambler1
Touring Parts
03-25-2010 07:48 AM
94fatboy
11-08-2009 06:21 PM
Quick Reply: Screamin' Eagle Big Bore Kit question.
