Q: 2006 Wide Glide Turn Signal Sense Wiring
Old 07-09-2010, 08:42 AM
Nisbet's Avatar
Nisbet
Nisbet is offline
Default Q: 2006 Wide Glide Turn Signal Sense Wiring
The previous owner changed the front turn signal units.
When he did it, he didn't realize that the extra blue wire was for computer sensing and he didn't reconnect those wires.
Now I am getting codes that the trun signal sensor is not working.
Can someone tell me:
Does the sense wire connect to the hot turn signal wire or does it connect to the return (ground) wire.
Thanks,
Bob Nisbet
Sr Technology Protection Engineer
Army Research & Technology Protection Center
Redstone Arsenal, AL 35898
Office: 256-876-1939
Cell: 256-797-4152
Old 07-09-2010, 09:42 AM
thedonthere's Avatar
thedonthere
thedonthere is offline
On my bike the blue wire is for the running lights. I unhooked mine and don't have a problem and never got any codes because of it.
Old 07-09-2010, 11:06 AM
Nisbet's Avatar
Nisbet
Nisbet is offline
Maybe the blue wire in the front is for running lights, but it is integral to the small sheathed wires that go to the turn signals on my bike.
Maybe the sense wires on the back signal units, if the front wire is for running lights.
Bob Nisbet
Old 07-09-2010, 12:29 PM
8541hog's Avatar
8541hog
8541hog is offline
Unless they made a change from 05 to 06, which I have not found to be the case on wiring, the blue wire on the rear lights is the running light, just as it is on the front.
Here is a simplified wiring diagram I made. The sensor for auto cancel is in the speed sensor, it senses change in speed to cancel the signals from what I have been able to figure out. Found this when I went to the digital gauge, auto cancel did not work without the speed sensor wire connection from the ECM.
Gnassty
08-28-2023 09:49 PM
Housegoat
07-30-2012 02:19 PM
backwods12
03-08-2012 10:26 AM
RICHIEMACK
01-05-2012 10:47 PM
Dan Theman
08-08-2011 09:55 PM
Quick Reply: Q: 2006 Wide Glide Turn Signal Sense Wiring
