street bob brake pedal adjustment
Old 06-30-2010, 05:43 PM
uer 84038's Avatar
uer 84038
uer 84038 is offline
Default street bob brake pedal adjustment
is there a way to move the brake pedal up on a 08 fxdb? or perhaps someone makes a pad that fits over the pedal to make it taller?
Old 06-30-2010, 05:52 PM
ghostrider69's Avatar
ghostrider69
ghostrider69 is offline
You can adjust the brake rod at the rear of it at the master cylinder. If it is already up against the foot peg bracket then you can not adjust it any more.
Old 06-30-2010, 05:55 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
as stated above it is a jam nut by the maser cyl, if that does not do it you may have to drill a new hold in the bracket to move it closer or further away or mod the pedal
Old 06-30-2010, 06:36 PM
uer 84038's Avatar
uer 84038
ill check it out. thanks!
Old 06-30-2010, 06:53 PM
07BlueScoot's Avatar
07BlueScoot
07BlueScoot is offline
I ground down the stock pedal flat and drilled a hole, used an aftermarket wide glide brake pedal pad.
Attached Thumbnails street bob brake pedal adjustment-100_0949.jpg   street bob brake pedal adjustment-100_0950.jpg
Old 06-30-2010, 06:57 PM
07BlueScoot
Forgot to mention it raised about 3/4".
Old 07-01-2010, 07:22 AM
uer 84038's Avatar
uer 84038
that looks like it would work. got a link to the pad you used?
Old 07-02-2010, 06:38 PM
07BlueScoot
Sorry man no link I bought it at a local shop, its a cheapo $14.95 but it half-assed matched my pegs Ha....
Old 07-02-2010, 07:32 PM
Centerline's Avatar
Centerline
Centerline is offline
That is a really clever idea and it looks great!
John CC
08-30-2018 09:56 AM
TxAnthony
01-07-2017 03:48 PM
kappy
06-11-2009 04:25 PM
WILLETTS
02-05-2009 06:27 PM
Schlager
07-07-2006 06:07 PM
Quick Reply: street bob brake pedal adjustment
