Driver Floorboard Insert Installation - HELP!
Old 06-23-2010, 08:18 AM
scottdoege's Avatar
scottdoege
scottdoege is offline
Default Driver Floorboard Insert Installation - HELP!
I just purchased these floorboard inserts off Ebay for my 2007 Ultra Classic. They were listed as fitting my bike.
FITS 5 AND 6 SPEED FLT, FLHT, FLHS, HERITAGE SOFTAIL & FATBOY MODELS 1980-PRESENT
STOCK REPLACEMENT (YOU CAN USE THESE TO REPLACE HARLEY INSERTS IN YOUR FLOORBOARDS)
REPLACES OEM #50187-96
SOLD IN PAIRS
95-RIB-INSERT-59
Upon receiving them, I removed my stock inserts with the rubber cushions and am not sure how to install them.
I don't think they are for my bike....
Any suggestions?
Thanks,
Scott
Old 06-23-2010, 08:57 AM
FLUltrarider's Avatar
FLUltrarider
FLUltrarider is offline
Are they an OEM HD part? If they are go online to the parts catalog look them up and usually they have installation instructions in .pdf format. Other than that, I got nothing.
Old 06-23-2010, 09:00 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
It looks like they are missing the rubber nipples that go through the holes on the floorboard pans.
Drew
Old 06-23-2010, 09:15 AM
scottdoege's Avatar
scottdoege
Default No OEM
These inserts are not OEM. They have a rubber pad under the chrome, but the rubber does not have the rubber nibs. I have asked the Ebay seller to refund my money because they are false advertised.
Old 06-23-2010, 09:16 AM
gibby122's Avatar
gibby122
gibby122 is offline
what the french toast? thats all you got, 4 metal peices? ummm... well, it looks like the small holes line up... guess your supposed to screw those together?
"They have a rubber pad under the chrome, but the rubber does not have the rubber nibs" - gotcha, guess thay're not made to float. im willing to be theyre made to be screwed together at those 4 holes that line up.
Old 06-23-2010, 10:44 AM
scottdoege's Avatar
scottdoege
Gibby122,
I tend to agree with you. Somehow I will need to bolt the bottom of the pan provided to my stock pan through the four large holes.
Then, I could pop-rivit (provided) through the slotted top insert through the rubber insert into the bottom pan using the four small holes.
The insert would not float, but is the floating really necessary?
Actually, I hope the Ebay seller will return them actually.
ickkey
Stock Harley Take Offs
08-10-2015 08:23 AM
Navy Mustang
03-29-2015 10:54 PM
bobbyjoes
08-07-2014 08:16 AM
ROVPLT
08-27-2009 10:43 AM
Glide2001
06-14-2009 01:43 AM
Quick Reply: Driver Floorboard Insert Installation - HELP!
