Max RPM?
Old 06-23-2010, 07:47 AM
bald1der's Avatar
bald1der
bald1der is offline
Default Max RPM?
I know that Rev Limiters are put on the bike to keep us from blowing it up, but it seems to me that the bike is still pulling strong when it dies from hitting the limiter. Has anyone increased their limiter? How is this done? I'd like to pull to about 6K on hard up shifts if possible. Would this hurt the motor?
Old 06-23-2010, 07:58 AM
Ridewva's Avatar
Ridewva
Ridewva is online now
The 211 cam must *really* change the power characteristic of the 96. Doesn't the PC-V have the ability to raise the limit?
Old 06-23-2010, 08:03 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
The Stage One download from Harley increases the rpm about 500 rpms as well.
Just a few minutes ago I read Donny Peterson's article in the new American Iron, where he states, "a Twin Cam, or any big twin for that matter, will not rev to 6500 rpm without the valves trying to change holes."
Old 06-23-2010, 09:22 AM
nemick's Avatar
nemick
nemick is offline
The PCV does allow the rev limit to be raised to 6200 rpm.
Old 06-23-2010, 09:26 AM
lipster's Avatar
lipster
lipster is offline
I think at 6700 rpm's or so, the pistons interchange holes as well.
Old 06-23-2010, 09:32 AM
jimsflh's Avatar
jimsflh
jimsflh is offline
If you haave a stage one upgrade, you can run 6200 RPM's (and I'm sure they figure in a margin of safety)
Old 06-23-2010, 02:12 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Not sure on the PCV but on the PC111 it is easily done. If I remember right just hit control F with the PC hooked up to your computer. A dialog box comes up to make the change.
Old 06-23-2010, 06:32 PM
bald1der's Avatar
bald1der
bald1der is offline
I'll have to look into the PC-V change.
Old 06-23-2010, 06:43 PM
Sgt. Fury's Avatar
Sgt. Fury
Sgt. Fury is offline
The Screamin Beagle ignition module in mine goes to 6200.
Old 06-23-2010, 07:31 PM
piasspj's Avatar
piasspj
piasspj is online now
I may be wrong but when you raise the rev limit with the PC the Tach may stop climbing even though the motor is turning faster.
Quick Reply: Max RPM?
