code-P1510 EFI Limited Performance Mode
Does anyone know what this means. I was riding today stopped for a break when I started back up the yellow light was on, when I checked the code this is what it was. I rode it for a while stopped and tried to clear it, but it would not clear kept coming back. I ate lunch went out about 1 hour later and then I was able to clear the code. So far it has not come back. Any Ideas? 2008 FLHTC with fuel pak and V&H Big shot duals.
https://www.hdforums.com/forum/gener...odes-dtcs.html
Good luck with your research.
Carl
I just love when everyone always says hit the search, which I did and the search on this site just plain sucks. Thanks for the post about how to read my codes, but if you read my post you would know I already know how, how do you think I got the code. I told you what the code is but it does not tell you what causes the code, and I thought that at least 1 other person might of had it at one time or another. Guess I am the only one with this code, but that does not make sense or they would not even have the code if no one gets it. Anyone?
In the two hours between posts, did you try the search function at the top of the page? If you type in P1510 you'll see a lot of threads including this one which lists DTC's and explains how to pull them:
Carl
Carl
Oh yeah I forgot my 2 hours between post's I have a life. I actually eat dinner and stuff like that and don't have time to read 1000 post about codes that have nothing to do with the code I threw.
Carl
Carl
And most of us do have a life, celebrate Father's Day, etc. so not getting a definitive answer within two hours isn't all that surprising.
It's great if someone has the right answer to a specific question, but it's also true that sometimes we have to search for an answer.
As for how to pull codes, I included that for a subsequent poster who didn't know how to do it.
Good luck with your search.
Carl
I didn't check the 51 theads but the 2010 Electrical Diagnostic Manual said:
P1510 Limited Performance:
Enables near normal
I'm not a tech, but sounds like a problem requiring prompt attention.
Carl
operation of the vehicle, guarding against inadvertent wide
open throttle conditions. Typically this code is the result if
(sic) one of the TGS or TP sensors, or one of each, has failed.open throttle conditions. Typically this code is the result if
Carl
