Go Back   Harley Davidson Forums > Harley Davidson Classifieds > Gear and Other Items For Sale
Sign in using an external account
Register Forgot Password?
Search
Notices
Gear and Other Items For Sale Helmets, gloves, leathers, etc. and any non-motorcycle related ads. Please read the rules for posting in this section.
Thread Tools Search this Thread
Old 06-19-2010, 06:03 AM
Donny2guns@gmail.com Donny2guns@gmail.com is offline
Hang Around
Default WTS: Clarke Welder 131E
Brand new never used arc welder. Comes with all accs. Here is a description of the welder:
The Clarke 120 Volt Arc Welder is the ideal professional welding kit for DIY and home workshops. Its simple to operate and completely portable. Volts: 120, Amps: 130 max peak amps, 90 continuous output, Duty Cycle: 20% at 75 Amps, Amperage Adjustments: Infinite, Weld Thickness (in.): 1/4in. in mild steel, Electrode Size (in.): 1/16 - 3/32, Electrode Cable Length (ft.): 8, Clamp Cable Length (ft.): 5.4 Single phase AC output only Variable heat settings Automatic thermal safety switch to prevent overload. Weld thickness up to 1/4in. mild steel Includes 5ft. 4in. 400 Amp ground clamp, cable, chipping hammer/brush, face mask and 8ft. electrode cable with holder
Asking $175 shipped. Contact Russ at Donny2guns@gmail.com or message me here thanks.
Tags
120, 131, 131e, arc, clake, clark, clarke, craiglist, model, parts, sale, volt, weld, welder, wts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Join HDForums
Advertising
Sponsors
Internet Brands, Inc.
