AMSOIL Severe Gear 75w90 in primary?
Old 06-17-2010, 08:04 PM
EXAMMO's Avatar
EXAMMO
EXAMMO is offline
Default AMSOIL Severe Gear 75w90 in primary?
Is it a good idea?
Old 06-17-2010, 08:13 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
transmission-yes, primary-no
Old 06-17-2010, 08:19 PM
twistr's Avatar
twistr
twistr is offline
Primary NO - Transmission - YES
Old 06-17-2010, 08:49 PM
lrays280z's Avatar
lrays280z
lrays280z is offline
Go to any convenience store....pick out the cheapest brand of Type "F" transmission fluid. Put in one quart and be done with it. Repeat every 10K miles. This stuff works great with the clutch plates. Also if you ever develop a leak you'll know if it's coming from the primary because the fluid will be "pink."
Old 06-18-2010, 05:23 PM
EXAMMO's Avatar
EXAMMO
EXAMMO is offline
What do you put in the primary?
Old 06-18-2010, 09:30 PM
Wecroft's Avatar
Wecroft
Wecroft is offline
I use Amsoil Motorcycle 20W50. You can use Syn3, or ATF fluid. Remember, there aren't any gears in that box, only a chain and sprockets and clutch plates.
Old 06-18-2010, 10:22 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Primary:
formula+
Syn3 20w50
10w40 Mobil1Vtwin
Mobil1ATF
BM trickshift
Redline MTL
Amsoil 10w40MCV
Mobil1Vtwin 20w50
Amsoil MCV 20w50
TypeF ATF
never 75w90 gear oil or any gear oil
Old 06-20-2010, 02:22 AM
EXAMMO's Avatar
EXAMMO
EXAMMO is offline
Thanks a lot guys. I am gonna pick up a new drain plug seal (gasket) from the dealer on Monday and change the primary fluid. I have a couple of extra bottles of AMSOIL 20-50 in the garage.
ken98k
EVO
25
07-04-2018 12:37 PM
por2gezo
04-25-2013 09:33 AM
01heritage
04-20-2009 10:05 AM
TIPN8R
08-10-2008 08:13 AM
Black Bart
25
07-24-2007 08:19 AM
Quick Reply: AMSOIL Severe Gear 75w90 in primary?
