Rear cylinder not firing
Old 06-13-2010, 12:03 PM
hog1957's Avatar
hog1957
hog1957 is offline
Stage IV
Default Rear cylinder not firing
Hi,
I got a problem with my 82 FXRS, it's a 93cui Stroker, S&S heads dual plug, Hi lift cam, roller rocker, S&S Super E with a Dyna S single fire.
During my last ride, the engine lost power and missfired. I had the same problem before due to a broken wire (according to the dealer). I checked the wires, changed the Dyna S, checked the coils( interchanged them), went with new ignition cables, checked continuity, no change!
Compression is good.
Any ideas?
Frank
Old 06-13-2010, 12:57 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Frank are you running suppression core wires off the coils if yes the one modules on the Dyna S might be bad How are your adv wts ?
Old 06-13-2010, 01:03 PM
hog1957's Avatar
hog1957
hog1957 is offline
Stage IV
No, and the Dyna S is brand new, I changed it today.
Old 06-13-2010, 01:11 PM
hog1957's Avatar
hog1957
hog1957 is offline
Stage IV
is there any way to test the adv wts?
Old 06-13-2010, 01:13 PM
hog1957's Avatar
hog1957
hog1957 is offline
Stage IV
I checked them today, they moved freely.
Old 06-13-2010, 05:52 PM
sqdealgeorge
I hope you're not running spiro wound plug wires !
Old 06-14-2010, 05:14 AM
Shane Hutchins Sr.'s Avatar
Shane Hutchins Sr.
Shane Hutchins Sr. is offline
Have you checked the wires from the Dyna to the coils for a break?
Old 06-14-2010, 09:01 AM
stevelonewolf's Avatar
stevelonewolf
stevelonewolf is offline
One common problen i've seen is if the rear cylinder is not firing, it was due to the Single fire ign.(Dyna-S)
PaPaBlista
09-12-2019 07:34 PM
PaPaBlista
Ironhead
06-19-2015 12:32 PM
bentsteel
Exhaust System Topics
05-19-2013 01:26 PM
Panhead Cooky
Panhead
03-20-2013 11:18 AM
deadhead 1200
General Topics/Tech Tips
10-14-2012 11:46 AM
Quick Reply: Rear cylinder not firing
