Classic All 'historic' bikes.
42wla ignition timing
Old 06-08-2010, 01:07 AM
paullavery's Avatar
paullavery
paullavery is offline
Default 42wla ignition timing
Can anyone give me a basic guide to setting up the timing on my wla, have just ordered an electronic ignition system from 45 parts depot, and seems straightforward to fit, but i know i have issues with the timing. Not really sure about the advance/retard position from the l/h/s grip ? where should this be positioned when setting up the timing ?
Thanks in advance, Paul.
Old 06-17-2010, 08:57 AM
jssurfer's Avatar
jssurfer
jssurfer is offline
pull plug on side of motor find the line on crank and center in hole then make sure your points are set to just opening w/ distributor turned in towards engine[full counter clockwise] tighten everything and it will be set properly.
Old 06-18-2010, 11:06 PM
paullavery's Avatar
paullavery
Thanks for that, still waiting for the electronic ignition to turn up in the post!
firsthd
12-12-2022 07:31 AM
RidemyEVO
EVO
04-28-2015 07:03 AM
mesmarter
EVO
11
08-14-2013 06:24 PM
Acemon
Shovelhead
11-16-2012 05:53 PM
badinfluence63
08-08-2008 09:01 AM
Quick Reply: 42wla ignition timing
