How close is the fuel moto map compared to a tune on a dyno with the PCV?
I just recently ordered a PCV from fuelmoto because i herd good things about there map it comes with for the mods on your bike. I was just curious if anybody has any before and after dyno runs with a fuelmoto canned tune and a fully dyno tune? If the fuelmoto tune that comes with the PCV is pretty darn close to a dyno tune i think ill pass on spending $$$$ on a dyno tune. This is one of the main reasons i bought the PCV from Fuelmoto because i herd there tune is pretty close to a dyno tune. The mods i have on my bike is rush mufflers and a SE Stage 1 AC
A full dyno tune by a competent tuner with the proper equipment works excellent, we very well know as we dyno tune bikes every day. I do however feel you will find the base maps we provide work very well and have been well proven to be very accurate.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Joseph Jerry Hache (12-26-2020)
bubbleb is right on this one. My bike has always ran good with Jamie's maps. But I have the auto tune. So with Jamie's assistant I have changed my AFR's to 13.2 and 13.4. Even though the bike ran good, over a period of time using the autotune I kept accepting the trim setting from the auto tune. My bike has went from 34 to 40 mpg and it runs so good! Also the trim settings is getting to the point that changes are minor. With these changes my bike is running also so much cooler. So I would get a dyno or the autotune. It will be worth it.
Received 69,975 Likes
You sure about that?
If the map and tune are close, I don't really see the value of a tune from a $$$ perspective...not for me anyway...maybe with another system but I don't think it would be significant or cost effective with a PC-V. JMO...
Another factor in this equation is the assumption that a dyno-tune will create a map that is as accurate as a Fuel Moto map, and that is a big "if". Unless the dyno-tune is thorough and done by a competent human tuner I personally would bet on the canned Fuel Moto map for the better accuracy.
Another example of the similarity of individual bikes of the same model is that EPA regulations are very strict, and every bike that rolls off the assembly line is equipped with the same ECU configuration, including the fuel map and ignition timing. Every bike must meet EPA regs, and if there was more than a slight difference between them in terms of emissions they would not be using the same map and would be tuned individually. I've talked with several experienced tuners and they all agree that like bikes will vary little in terms of tuning, and a map on one bike will work perfectly in another of the same model and year.
The bottom line is that a PCV map created by Fuel Moto in MN will work fine in another bike run in another location. Running a basic PCV in open-loop (i.e. not auto-tune), the MAP and other sensors compensate very well for changing environmental conditions like altitude, temperature, barometric pressure, etc.
I would have to agree that the Fuelmoto maps are very close and there is not much to be gained by a dyno. I've had 2 dynos in the last 3 years on my 07 all with the PC111 I purchased from Jamie. Different but competent tuners. Both showed modest improvement not even felt on my butt dyno. Possibly a little better response.
Finally got a laptop and have been doing a bit of experimenting. I went back to Jamie's map with modifications I made to the cruise range as I do feel his maps are too rich in this area. Zero to 20% throttle up to 3000rpms. Keep in mind my bike is a very early 07 purchased in August, 06 and PC was installed in Sept. 06 so there could have been a learning curve with the new, at the time, 96" motors.
Bike runs great and need one more good ride to determine if I'll stay with the Fuelmoto map. Even if I don't I now think any gains from the dynos were minimal.
Assuming your asking me, about 3 hp, 2 tq. Then the next guy added about the same.
Keep in mind tho that both tuners were able to see the previous guys tune and numbers.
No way they are going to come up with poorer results.
Bottom line is that I wound up with 75hp, 88tq for a stage 1 96" which is about average from what I've seen.
