Tire pressure
Old 05-30-2010, 11:46 AM
pcbunn's Avatar
pcbunn
pcbunn is offline
Default Tire pressure
Just curious what tire pressures Wide Glide owners are running? Manual says 40 rear and 30 front. On other bikes I've dropped the recommended pressure by 2-4 lbs unless I'm traveling long and heavy but for local runs a few pounds less seems to give a bit better ride quality. Any down side to say 36 rear and 28 front?
Old 05-30-2010, 12:46 PM
Cornhusker's Avatar
Cornhusker
Cornhusker is offline
Manual for 07 FXDB says All Models, 36 lbs back (if riding double, 40 lbs.) 30 lbs Front. That's about where I keep them. That's the specs for the Dunlops that the MoCo uses. Probably different with other tire mfgrs.
Old 05-30-2010, 01:24 PM
watchluvr4ever's Avatar
watchluvr4ever
watchluvr4ever is offline
Under inflated tires can affect braking and also accelerates tire wear.
Old 05-30-2010, 01:30 PM
07 dyna man's Avatar
07 dyna man
07 dyna man is offline
run 40psi in the front because of the small side wall one good pot hole and u got a bent rim i also rum 35 in the rear
Old 05-30-2010, 01:48 PM
skunk ape's Avatar
skunk ape
skunk ape is offline
oops wrong thread
Old 05-30-2010, 01:54 PM
ThrusterK's Avatar
ThrusterK
ThrusterK is offline
Riding single I run 36 rear, 30 front, if I have a passenger, I raise the rear to 40.
Old 05-31-2010, 01:12 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is online now
Received 1,811 Likes on 1,064 Posts
:icon_ rtfm:: icon_rtfm::icon_r tfm:
Old 05-31-2010, 01:36 AM
rounder's Avatar
rounder
rounder is offline
gonna depend on your weight. If your lighter rider, a few lbs less pressure won't hurt. However it is probably better to run the recommended pressure if your over 190 lbs. I run 40 rear and 35 front on my metzelers. I do get a softer ride with the 30 in the front, but I still would rather run the 35psi as it is better for the metzeler tire. You won't die or put yourself in any real danger being a couple psi off the recommended pressure.
Old 05-31-2010, 09:08 AM
pcbunn's Avatar
pcbunn
pcbunn is offline
Thanks to all for the comments. I'll stay with the recommended 30psi in the front but will drop the rear from 40 to 38psi and see how it runs. Thanks again!
Old 05-31-2010, 04:43 PM
ynots's Avatar
ynots
ynots is offline
Here is a tip I always follow for maximum tire life and handling
Run the recommended inflation pressure for a COLD tire.
Drive bike 10 miles.
Ideally your tire psi should (only) increase 10%.
Air temp and weight will make a difference.
Adjust PSI as necessary
Quick Reply: Tire pressure
