polishing aluminum lower forks
Old 05-26-2010, 01:41 PM
hdonly4me's Avatar
hdonly4me
hdonly4me is offline
Default polishing aluminum lower forks
Has anyone polished the aluminum lower forks on a Heritage to make them shine like chrome? What process of sanding and polishing did you use? Were you satisfied with end result? Thanks
Old 05-26-2010, 03:19 PM
89FLHT's Avatar
89FLHT
89FLHT is offline
I've done it all by hand in my garage for my last 3 bikes.
I remove the fender and wheel and install the axle to keep the fork tubes aligned.
Dry sand starting with 200 grit, 300, then 400, then wet sand with 600 and 800.
from there I wet sand with #1, #0, #000 steel wool dipped in Flitz metal polish.
Very happy with the results.
Takes a solid day to do both legs. But once they are done, it is very easy to maintain. When the bike gets cleaned, I just run over the legs with Flitz and the #000 steel wool and it really makes them gleam.
Old 05-26-2010, 03:30 PM
DaFish's Avatar
DaFish
DaFish is offline
Like 89FLHT said. You can use a drill and buffing pad once you get to that point. I used the white and brown rouge. They still sparkle. I use Mothers Metal Polish to keep em shining.
To me it was worth it.
DaFish
Old 05-26-2010, 04:06 PM
moondog99's Avatar
moondog99
moondog99 is offline
Here is how I have done the last couple of bikes I have had. Remove fender, strip clearcoat off with a chemical paint stripper, wet sand starting with 400 grit, 600grit, 800 grit and finish sanding with 1500 grit. You can do this by hand but on areas not so tight I cheated and used a palm sander with a spray bottle. Then I attached a 4" sewn polishing wheel to my drill using a long bolt and some washers and buffed it using Flitz metal polish. And afterwards just touch up every three months or so with either aluminum tool box polish, Flitz or Brasso. Takes about 5 hours from taking off the fender to riding. Absolutely no regrets, get some beer turn on some tunes and get started!
Old 05-26-2010, 04:26 PM
mickymoto's Avatar
mickymoto
mickymoto is offline
sanded wet with 800, 1200, 2000, ultra fine, then mothers power cone or ball on power drill ( cordless didn't work as well...not enough speed/heat) using aluminium polish then regular polish.....result: not chrome but vast improvement & looks like it from 15 foot away, don't rush it, each step done well makes for a better finish.
Old 05-26-2010, 06:22 PM
hdonly4me's Avatar
hdonly4me
Thanks guys. Hey Moondog what did you say? I was distracted.
Old 05-26-2010, 06:51 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Its worth the effort, looks good. Use the paint thinner method then start with 400 grit up to 2000. Mother Al polish works great.
Old 05-26-2010, 08:12 PM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,055 Likes on 631 Posts
some good tips here , I did mine with steel wool
Old 05-26-2010, 08:16 PM
dennyo's Avatar
dennyo
dennyo is offline
Old 05-26-2010, 11:06 PM
moondog99's Avatar
moondog99
LOL I know half the time I log on here I just sit and stare myself.
Quick Reply: polishing aluminum lower forks
