Brake Fluid Level Check
Old 05-25-2010, 07:41 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
Default Brake Fluid Level Check
Should the bike be level and upright when checking brake fluid level in the master cylinders? Owners manual doesn't say. I think yes but not sure on this one. 2010 EGC
Old 05-25-2010, 07:53 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
You want the master cylinder to be level to prevent any spillage thats all that maters.
So for the rear brake Yes have the bike level.
For the front brake move your handlebars to whatever position gets it as level as possible.
And dont get any on your paint!
Good luck.
Old 05-25-2010, 08:16 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
Front……..on jiffy stand, turn handlebars left.
Rear….MC vertical, if possible.
…….at least on my bike.
Old 04-12-2012, 05:58 PM
PGDredd's Avatar
PGDredd
PGDredd is offline
and what is the fill lever on the rear MC? I am a touch low but the manual does not say how far to fill it....
Old 04-12-2012, 06:38 PM
2black1s's Avatar
2black1s
2black1s is offline
A touch low as you say is probably ok. Personally, I would only fill it full if I had brand new brake pads. As the pads wear the fluid level will go down. If you fill the master cylinder with used/worn brake pads then it will be overfull and quite possibly overflow when you depress the caliper pistons for new pads.
rwt
06-22-2017 06:58 PM
EasTexUltra12
07-14-2014 09:21 AM
NYSportster
Wheels/Tires
33
02-14-2009 09:39 AM
617south
05-24-2008 08:08 PM
chamonix
11-24-2005 01:15 PM
Quick Reply: Brake Fluid Level Check
