Noise in 4th Gear
Old 05-24-2010, 10:18 PM
FLHFred's Avatar
FLHFred
FLHFred is offline
Default Noise in 4th Gear
'06 Road King Classic,15,000 miles. I was on a weekend ride a few weeks ago. Started hearing a noise that sounds like a small turbo charger winding up every time I shifted into 4t gear. If I run in 4th at a steady speed you don't hear it as much or not at all. 1-2-3 and 5th gears are quiet. Only hear it in 4th and its loudest when accelerating. Changed the transmission fluid today the magnet on drain plug had a couple of small filings on it. This must be normal because the service manual said to be sure to clean the magnet before inserting it back into the transmission. So, my question is, whats causing this sound in 4th gear and is it anything to worry about? Thanks for your time, FLHFred
Old 05-24-2010, 10:44 PM
fladawg01's Avatar
fladawg01
fladawg01 is offline
Default Gear Noise
I have an 06 Ultra similar noise in 4th. Some have stated the newer 6 speeds have a noise in 5th. I guess HD decided to let you know you have one more gear!
I had my tranny checked and flushed by my indy. He also put in Spectro Synthetic tranny fluid. Still have the noise, and the last drain of the tranny fluid looked like it was still new. No chips, shavings etc.
Old 05-24-2010, 11:21 PM
PNSHVL's Avatar
PNSHVL
PNSHVL is offline
I have a 2006 Road Glide that I bought new and now has 35,000 miles on it. It always had a strange winding noise every time in 4th gear. Never had any issues with it and I always know when I'm in 4th. I've run Harley tranny fluid, Torco, Ams oil, it never changes.
Old 05-24-2010, 11:40 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Its the exact same noise everybody that has a 6 speed has been complaining about in 5th since 07 and the same noise that Ive been telling them 5 speeds had in 4th, no big deal.
Old 05-24-2010, 11:45 PM
Enforcer419's Avatar
Enforcer419
Enforcer419 is offline
'05 FLHTC and have the same noise in 4th gear also. Just under 30,000 miles.
Old 05-25-2010, 12:21 AM
leon anthony's Avatar
leon anthony
leon anthony is offline
same thing with my 06 ultra 85000 miles no problem
Old 05-25-2010, 01:33 AM
sifularson's Avatar
sifularson
sifularson is offline
Change to Redline transmission oil and the sound will be gone.
Crashrdking01
03-03-2018 01:22 PM
TheSter
05-28-2012 11:01 AM
yellow cab
09-28-2007 04:08 PM
74shovel
Shovelhead
08-23-2007 07:41 AM
acedantinne
12-04-2006 08:29 PM
Quick Reply: Noise in 4th Gear
