What is the shortest route thru 48 states?
Old 05-21-2010, 11:52 AM
PickyBiker's Avatar
PickyBiker
PickyBiker is offline
3rd Gear
Default What is the shortest route thru 48 states?
Has anyone put together a map or route through the 48 contiguous states? Fastest route, shortest route, most scenic, etc.
Old 05-21-2010, 01:55 PM
bentryder's Avatar
bentryder
bentryder is offline
Received 5,302 Likes on 2,157 Posts
I did see a map....years ago...that went thru the 48....none of it on the slab...went thru each state once...no back trackin....don't remember where i saw it but give it a google....i'm sure its out there somewhere.......
Old 05-21-2010, 03:23 PM
lfmn16's Avatar
lfmn16
lfmn16 is offline
Default Iron Butt site should have one
Try IronButt.com or IronButt.org. I'm sure if you look around or post, someone will have one. If not them, the Motorcycle Tourers Forum, http://forums.delphiforums.com/MCTourer/
Last, but not least, if you can find a copy of Ron Ayers, Against the Clock: The incredible story of the 7/49, he maps out his route of visiting the lower 48 plus Alaska.
Old 05-22-2010, 08:19 AM
sidecar79's Avatar
sidecar79
sidecar79 is offline
http://wot.motortrend.com/6246632/mi...rip/index.html
Not a good motorcycle route but may help
SturgVirg
Road Trips
03-15-2015 07:26 AM
MNPGRider
05-16-2014 06:30 PM
CipoWins42
03-09-2014 03:27 AM
Candubrain
Road Trips
02-26-2012 08:01 AM
SCS
04-11-2006 12:22 PM
Quick Reply: What is the shortest route thru 48 states?
