Tow Behind Trailer wiring question
Old 05-17-2010, 10:25 AM
jsimo7's Avatar
jsimo7
jsimo7 is offline
Default Tow Behind Trailer wiring question
Where do the trailer pullers tap into the wiring harness to get power for the tail light, brake light, and turn signals. Do you tap in at the tailight and T/S bar or under the seat? I have a 08 Ultra. Thanks
Old 05-17-2010, 10:50 AM
davep's Avatar
davep
davep is offline
You can buy an adaptor from J&P Cyles that plugs into the harness under the seat on your bike and connect the wiring harness from to that. No splicing into the main harness.
This nice if you want to move harness to another bike. Part number for this 300-077 (Trailer wiring plug) $39.99. This is a clean way to connect your harness.
Old 05-17-2010, 02:29 PM
Artur's Avatar
Artur
Artur is offline
I use this on my 08 ultra...
http://timeouttrailers.org/accessories.aspx
The Wiring Schematic that we use is:
Pin 1 - Yellow Wire - Left Turn Signal
Pin 2 - Green Wire - Right Turn Signal
Pin 3 - Brown Wire - Running Lights
Pin 4 - Red Wire - Brake Lights
Pin 5 - White Wire - Ground
We use a 5 wire round plug on all our trailers unless
otherwise specified. The bike end harness comes with
your new trailer purchase as well.
Old 05-17-2010, 04:49 PM
jsimo7's Avatar
jsimo7
jsimo7 is offline
Thanks .. That looks like a clean easy way to go
Old 05-17-2010, 05:32 PM
dougbk's Avatar
dougbk
dougbk is offline
I used the Y adapter that plugs into the wiring connections under the seat to control the isolator that pulls its power off the battery. That way your wiring circuit doesn't take the extra load.
Y adapter
http://www.shop.american-legend.com/...5&categoryId=8
Isolator
Old 05-17-2010, 06:50 PM
jsimo7's Avatar
jsimo7
jsimo7 is offline
Is the isolator needed for a trailer with 2 tail/brake/turn sig lights and 4 marker lights? 6 bulbs total . Thanks
Old 05-17-2010, 09:13 PM
dougbk's Avatar
dougbk
dougbk is offline
Not sure if iy is, but I figured better safe than sorry, with the ecm.
Old 05-17-2010, 09:52 PM
Rustell's Avatar
Rustell
Rustell is offline
Old 05-17-2010, 10:20 PM
cap5369's Avatar
cap5369
cap5369 is offline
I bought the adaptor that is a plug and play, then just use the color code that comes with the hitch's harnes. No you don't need the isolator, I had it the first time and it burnt up. Ride safe
Old 05-17-2010, 11:18 PM
Casper's Avatar
Casper
Casper is offline
I have one of the adapters from J&P, used it on my 07 Classic, but damm if I can find anywhere to use it on my 2010 RG....any help with this?
Quick Reply: Tow Behind Trailer wiring question
