.900 offset sprocket hits inner primary
Old 05-11-2010, 06:13 PM
graves1's Avatar
graves1
graves1 is offline
1st Gear
Default .900 offset sprocket hits inner primary
I just got a .900 sprocket for my project and it hit the inner primary i thought that this was as big as you can run with out hitting do i need to grind the primary to make it fit or what it is hitting around the bearing housing any help would be great thanks in advance
Old 05-11-2010, 08:18 PM
03dragonRK's Avatar
03dragonRK
03dragonRK is offline
If it's just hitting the ribs you should be safe removing a little material there. Leave a gap of at least .060 between the cace and sprocket to allow for heat expansion. If it looks like you are going to have to remove a lot on material then I would go to a .75 offset.
jurgie
05-21-2017 07:11 AM
aviscomi
12-02-2015 09:52 AM
hawgriderbc
06-15-2011 09:07 PM
skins71
02-09-2009 02:25 PM
orange93fxstc
08-18-2008 03:23 AM
Quick Reply: .900 offset sprocket hits inner primary
