Removing the starter motor
Old 05-11-2010, 05:30 AM
mucklepilly's Avatar
mucklepilly
mucklepilly is offline
2nd Gear
Default Removing the starter motor
I need to pull the starter motor out of my 1997 Dyna FXDS. It looks like a case of diconnect the battery, unclip the "trigger" wire, undo two allen bolts and slideit out.
Is it really that easy or will I find something more scarey when I try? Also if anyone can tell me the allen key size needed for the main bolts that would be just groovy too.
Thanks heaps.
Mucklepilly.
Old 05-11-2010, 05:41 AM
sniper77's Avatar
sniper77
sniper77 is offline
1/4" two bolts. two wires.
Of course, that is after you remove the outer primary and remove the starter jack shaft bolt.
Old 05-11-2010, 07:25 AM
reded's Avatar
reded
reded is offline
Don't forget to pick up a new lock washer for the jackshaft bolt. The lock tab will break off upon re-assembly, the bolt will eventually back out and leave you F'ed in the middle of nowhere!
Old 05-11-2010, 07:29 AM
mucklepilly
2nd Gear
Sh*t, I know it couldn't be that easy. OK, now when I remover the outer primary cover is there anything that'll go clunk and fall down behind it never to be seen again or is it just a cast of drain it and remove the cover?
Are there any tricks to removing the jack shaft?
Is it normal to have to replace gasket(s) when you re-fit the cover?
What type of and how much oil will it take to re-fill it?
Questoins questions I know, but I'm gonna try this myself and I haven't worked on a Harley before.
Mucklepilly.
Old 05-11-2010, 07:44 AM
reded's Avatar
reded
reded is offline
1. Drain oil and remove cover
2. Remove jackshaft bolt.
3. Pull the starter.
I'd replace the cover gasket while your in there and check the primary chain tension. Any top grade oil that doesn't contain friction modifiers is fine for chaincase use, approx. 1 qt.
The side of the coupler with the longer splines goes on the starter. You'll know what I mean when you see it.
Once you take the cover off, snap a couple pics of the assembly for future reference. Nothing will fall out that you cant easily recover. It's not a bad job, just sucks that it requires one to get oily.
Old 05-11-2010, 11:02 AM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Default Torque
Make sure you tighten the primary back up in the order in which they show you in the book using a torque wrench and don't forget the sandwiched small round gasket that goes on the center inspection cover bolt tube on the inner primary between inner and outer cover.
Old 05-11-2010, 11:54 AM
reded's Avatar
reded
reded is offline
There should be two of these gaskets. They're called tower gaskets.
Old 05-11-2010, 12:26 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Thanks, Yes thats right. I should have mentioned two gaskets. I'm not sure if the person would have been able to decipher what a tower gasket is without a description? Thanks for clarifying.
Old 07-07-2015, 05:32 PM
rustybit's Avatar
rustybit
rustybit is offline
Stage III
Reusing a gasket no matter how new is always a calculated risk. Replacing the gasket is a piece of mind. However, if the bolts aren't torqued properly you can bet it will leak, and you'll have to do the job over once again, with a "New" gasket and sealant. Now is the time to check the stator. Visually check the coils, and the wiring both inside and outside primary housing. Avoid handling stator coils, and do not rock back and forth to test sturdiness. Check inside flywheel cover for arcs. (Electrical spikes) And, lastly visually check the gears, chain for wear. You’re looking for abnormal wear. As this will affect how the chain rides on the pad. Check the Chain Tensioner pad. If the pad is worn excessively the chain tension is probably too tight. It needs to slack off some by its self. The Tensioner may be faulty. I replaced the Pad on mine for peace of mind. Check the tensioner groves carefully as they tend to wear down and will cause the chain to tighten or slacken prematurely. If there is any other signs of wear on the pad (irregular groves caused by chain whipping) replace the entire tensioner and pad. If in doubt ask questions. Always check and recheck your work. At least that’s how they taught us in the military. Hope this helps.
Old 07-07-2015, 05:43 PM
Hippie49's Avatar
Hippie49
Hippie49 is offline
Five year old thread.
He's probably got it by now.
Quick Reply: Removing the starter motor
