Sponsored by: Jekill and Hyde
leaking oil at stator wire.
Old 05-10-2010, 07:24 PM
arthurn's Avatar
arthurn
arthurn is offline
Default leaking oil at stator wire.
I have an 08 Road King 2 yrs later and 25,000 miles later I have developed an oil leak where the stator wire exits the crankcase. I have done some research so I know sometimes it's because oil is leaking past the crank shaft oil seal and filling the primary. The oil in my primary is at the bottom of the clutch hub. I tried filling in the gap between the rubber gasket/plug with rtv silicone and this slowed the leak from a drop a day to just an oil sweat. I am thinking that the next step is to pull the chain case, replace the stator, but I am also thinking, that I should change the oil seal as well. I can read a book, and can work with my hands but this is all new to me. I have the manual and on my sportster I changed my cylinder gaskets because of an oil leak and did ok. My question is, #1 Do you think I should change the compensating sprocket shaft oil seal on the crank shaft, and if so how do you pull it with the engine still in the bike? The manual shows how to pull it with the cases split. Any info/help will be appreciated.
Old 05-10-2010, 07:50 PM
Scootrskum's Avatar
Scootrskum
Scootrskum is online now
Mine was leaking pretty badly and it was nothing more than a crappy seal where the plug goes through the case. Put some hi-temp oil resistant silicone around the plug on the INSIDE of the primary and no problems since. Been a year or more now....
Old 05-10-2010, 08:38 PM
soft 02's Avatar
soft 02
soft 02 is offline
+1 on sealing it with silicon. With that many miles if you do pull the compensator seriosly look at the SE compensator. Do a thread search on it. The stock compensators in the 96" motors are junk. The should have used the se ones as a stock item. Their is some good info on this subject.
Gibby13
06-26-2023 11:31 AM
freddyg
EVO
06-22-2013 11:02 AM
sargek
11-01-2011 02:01 PM
SHAKEME
10-07-2010 01:48 AM
supr2nr
Ironhead
05-11-2008 10:53 PM
Quick Reply: leaking oil at stator wire.
