Finally a solution to my flush mont LED gas caps
http://www.cycleoutfitters.com/produ...catalogId=1570
They aren't exactly flush, but they are low profile.
I have the HD flush mount LED gauge and matching pop-up cap.
LED's are mostly not working and look like R2-D2 lights when some are working and some aren't.
Pop-up gas cap needs constant lubrication to keep it working. Most of the time I have to pry a credit card under it to get it to "pop" up.
I hope to Jesus this works as advertised.
I've heard that the "newer" version of HD's work much better, but at nearly $200 I'm not going to risk it.
I'll actually be happier not to have all those blue lights glaring at me (when they chose to work).
Finally got these and got them installed. I think they look good. They aren't flush, but they are low profile. The single LED on the left side "cap" is amber and only comes on when you're low on fuel. There is a button on the bottom and you can set the level in which you want it to come on. Mine is set at 1 gallon.
Do you have a tank lift? I like the feature of being able to set the float. My gauge is off by about a gallon because of my tank lift, so I just keep track of mileage, but the dash board gas idiot light is annoying.
Does use of this gauge leave the stock light out of the loop so to speak?
USMAMule
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
