Chain case oil
Old 05-01-2010, 04:49 PM
Route66rider's Avatar
Route66rider
Route66rider is offline
Smile Chain case oil
A real quick question here. As it is storming here, I decided to go ahead and change the oil in my 05 UC. I have a quart of both Mobil 1 75/90W synthetic and Redline 80W shockproof. Which should I use in the chaincase?
Old 05-01-2010, 04:52 PM
SoCalRoadGlide's Avatar
SoCalRoadGlide
SoCalRoadGlide is offline
If you're talking about the primary chain case, I wouldn't use either.
Old 05-01-2010, 04:55 PM
sifularson's Avatar
sifularson
sifularson is offline
Gear oil goes in the transmission. You would be better off to just use motor oil in you primary. I use Redline Primary oil. Some guys use motor oil and some even use ATF. Do a search to learn more.
Old 05-01-2010, 04:59 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Yep.I use Valvoline 20/50 motorcycle oil.
Old 05-01-2010, 05:05 PM
Route66rider
OK, so you are saying that I should use the same Mobil 1 V-Twin 20-50W oil in the primary chaincase as I used in the motor?
FWIW, I used the Mobil 1 V-Twin 20-50W in the motor & Redline V-Twin with shockproof in the transmission.
Old 05-01-2010, 05:07 PM
1flhtk4me's Avatar
1flhtk4me
Yes that will work.
It's printed on the label.
Old 05-01-2010, 05:08 PM
SoCalRoadGlide
That would work fine. HD is shipping their motorcycles with Syn3 in all 3 orifices. I feel the Syn 3 is too light for the tranny, but that's just me.
Old 05-01-2010, 05:33 PM
Route66rider
Still new to this Harley maintenence. The Redline 80W gearoil is marked as being specially formulated for wet clutches...
Old 05-01-2010, 05:39 PM
hawwk's Avatar
hawwk
hawwk is offline
The 80w is to heavy for the chaincase save it fot the trans. Get some atf or motor oil and use it.
Just my .02 cents
Old 05-01-2010, 05:54 PM
hawg50's Avatar
hawg50
hawg50 is offline
b&m trick shift automatic trans fluid type f is a good alternative.most of the racers in top fuel and funny car use it in their clutches.
Quick Reply: Chain case oil
