Twist grip sensor 32310-08: wire colors
Old 04-24-2010, 06:53 AM
x1rider's Avatar
x1rider
x1rider is offline
Default Twist grip sensor 32310-08: wire colors
I got my 124" StreetGlide started yesterday, but it will only start if I unplug the twist grip sensor. When I put my Monkey Bars on, I switched for the twist grip sensor 32310-08 so the green connector wouldn't be in the way.
The new TGS has a red, white, and black set of wires in a black wrap and a red, white, and black set of wire in a yellow wrap.
Does anyone know which is which when compared to the stock TGS diagram below?
I followed instructions I found previously but it didn't work (I'll recheck my connections this afternoon, maybe I didn't push a pin far enough in the plug). The funniest thing is that I'm not getting a DTC, and the bike will only start with the TGS unplugged.
One more question, should I see some changes while logging with DataMaster when twisting the grip with the ignition on but the bike not running.
Thanks in advance for any assistance.
Old 04-24-2010, 07:01 AM
'05Train's Avatar
'05Train
'05Train is offline
Sounds like something isn't connected right. I followed the directions posted here and had/have no problems. Have you re-checked everything?
Old 04-24-2010, 07:03 AM
x1rider's Avatar
x1rider
x1rider is offline
Is this here what you followed?
Wires from black sleeve go in 1,2,3
1-black
2-white
3-red
Wires from the yellow sleeve to in 4,5,6
4-black
5-white
6-red
Thanks
Old 04-24-2010, 07:08 AM
'05Train's Avatar
'05Train
'05Train is offline
It's been a few weeks, but that looks right. It took me a couple of tries to get the pins seated properly in the plug.
Old 04-24-2010, 07:11 AM
x1rider's Avatar
x1rider
x1rider is offline
OK, thanks a lot, that's the instructions I followed too. I'll try re-seating the pins again. I hope it's not a faulty TGS, I'd rather poke needles in my eyes than thread those wires through those Monkey Bars again.
Old 04-24-2010, 07:25 AM
x1rider's Avatar
x1rider
x1rider is offline
Check out page 6 on this (referring to 32310-08)
https://www.shop.harley-davidson-ros...s/56032-08.pdf
It's the opposite of the previous instructions, it says
yellow conduit
black to cavity 1
white to cavity 2
red to cavity 3
black conduit
black to cavity 4
white to cavity 5
red to cavity 6
I hope I didn't fry anything.
Old 07-30-2010, 02:12 PM
gtrplyr's Avatar
gtrplyr
gtrplyr is offline
yellow conduit
black to cavity 1
white to cavity 2
red to cavity 3
black conduit
black to cavity 4
white to cavity 5
red to cavity 6
Did you ever find out which one of the diagrams for the wiring was correct? Does the Yellow conduit go to cavity 1-3, or does the Black go to 1-3?
Old 07-30-2010, 03:06 PM
x1rider's Avatar
x1rider
x1rider is offline
The one I posted worked, the other one didn't.
Old 07-30-2010, 03:18 PM
gtrplyr's Avatar
gtrplyr
gtrplyr is offline
You posted both... LOL! Which one? Thanks!
Old 07-30-2010, 04:59 PM
x1rider's Avatar
x1rider
x1rider is offline
sorry, I've posted this a long time ago. Follow the instructions in the H-D link I posted and that's what worked for me.
Quick Reply: Twist grip sensor 32310-08: wire colors
