Front brake is squealing
Old 04-22-2010, 01:15 PM
Fat Boy 08's Avatar
Fat Boy 08
Fat Boy 08 is offline
Default Front brake is squealing
What I pull up to a stop sign, my front brake will squeal real loud. It only does it at slow speeds. It started this when my bike was only a few months old. It sounds like a city bus pulling up to the stop sign. I took it to the dealer and the guy said that can happen with a hard mount brake. He said "that's a Harley". They did take off the brake pads and put some anti-vibration stuff on them. This helped for a day or two. Does anyone have any suggestions on how to fix this?
Thanks
Old 04-22-2010, 01:45 PM
nikonf8's Avatar
nikonf8
nikonf8 is offline
Default brakes
two things would make my brakes squeal one was when they got wet the other was break dust which also killed my whitewalls. I installed Lyndall brake pads which took care of the break dust. all was well with the squealing until they got wet then the squeal came back for awhile and goes away when driven and they dry. You may be stuck with it until your ready for new pads some times cleaning them with break clean will help.
Old 04-23-2010, 07:33 AM
tk353's Avatar
tk353
tk353 is offline
there is a third reason the brakes squeal. and i switched to lyndall and they still did what you have. it was a defective front rim that caused the wheel bearing to squeal and wear out very fast. get the dealer to check that. my dealer missed it 2 times but fixed it after me driving 50,000 miles like that
Old 04-23-2010, 08:28 AM
Ole Coyote's Avatar
Ole Coyote
Ole Coyote is offline
Well, come on, it is a Hog after all, it should squeal.
Coyote
Old 04-23-2010, 08:38 AM
Fat Boy 08's Avatar
Fat Boy 08
Would you recommend the Lyndall Z-Plus or Gold Plus pads?
Old 04-23-2010, 11:58 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
we recommend the z plus pads for most applications. If you wanted some we have them in stock for $41 a set. Also there is a good post on lyndall racing brakes website showing how to clean the brake calipers which also can help. Here is the link below.
http://lyndallracingbrakes.com/service_tech.htm
Old 04-24-2010, 09:58 AM
'05Train's Avatar
'05Train
'05Train is offline
Lyndall Z+ pads with H-D floating rotors. Make sure you clean the pistons when you switch pads. Use the anti-squeal monkey snot on the back of the pads, and lube your caliper pins. No squeal, no squeak, no dust, just powerful stopping.
John CC
08-26-2019 03:46 PM
Chuck1
06-23-2017 12:36 AM
Rickr01
08-07-2012 03:04 PM
booboo
05-19-2008 04:43 PM
StargazerXT12
05-24-2007 04:59 PM
Quick Reply: Front brake is squealing
