04 Ultra Blowing Acc Fuse?????
Old 04-11-2010, 08:43 PM
CCNitro's Avatar
CCNitro
CCNitro is offline
Default 04 Ultra Blowing Acc Fuse?????
My buddie has an 2004 Ultra/88"/5spd. while we were riding today, his gauges,brake lights,etc quit working, come to find out it was accessory fuse/15amp mini located under kickstand side cover fuse box. replaced it and 5 mins into the ride it blows it again, weve search almost everything, as in bare wires and such. any "ideas" has anyone had this happend?? the bike still runs,starts and all, just the accessories dont work. the fuel gauge/low fuel light did stop working several months ago, would replacing fuel sending unit be a good place to start??
You guys helped me on my ride, hope you can help fix this issue!
Old 04-11-2010, 08:57 PM
dawg's Avatar
dawg
dawg is offline
Received 2,965 Likes on 1,715 Posts
It's wiring somewhere. When this happened to me it was the rear brake switch wiring chaffing on the bolt that attaches my exhaust to the transmission bracket. Places to check would include under the rear fender and in switch housings.
Old 04-11-2010, 09:11 PM
CCNitro's Avatar
CCNitro
CCNitro is offline
We will check this are out tomorrow, Thanks!
Old 04-12-2010, 12:21 AM
Denver_Rick's Avatar
Denver_Rick
Denver_Rick is offline
another thing to check would be the accessory jack, on my 08 its packed up in front of the battery box make sure the wires are not chaffed.
Old 04-19-2010, 12:31 AM
ecvjohnny's Avatar
ecvjohnny
ecvjohnny is offline
if you have the manual and locate which fuse it is, it'll help identify what circuit is the problem.
Old 07-26-2010, 09:56 AM
thecurti's Avatar
thecurti
thecurti is offline
Any update here? I'mNew to the forum here, but I am having the same problem with my 98 Eglide.
Curtis
Old 07-26-2010, 11:12 AM
rh8234's Avatar
rh8234
rh8234 is offline
First place I always check is the last place I did some work. If you've had the switch housings off, for example, look for a pinched wire in them.
Old 07-28-2010, 05:16 PM
CCNitro's Avatar
CCNitro
CCNitro is offline
Curtis
Sorry for the delay!! but he never found out why the fuse was blowing. instead he replace the fuse with a trip circuit breaker. and to this day I dont think that he has had to reset it. ?? Sorry I couldnt help any more than that. hope you find the issue.
Badboy01
08-31-2015 01:15 PM
MichiganDave
06-16-2013 07:41 PM
ndnbennyb
05-09-2013 12:19 PM
CCNitro
04-12-2010 06:08 AM
Newhog
03-13-2007 05:28 PM
Quick Reply: 04 Ultra Blowing Acc Fuse?????
