Calling all FatBoy Lo Owners
  #6871
Old 05-05-2012, 09:14 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
Originally Posted by CaptainMorgan_SOS
So just an update: the bike is STILL up on blocks! I had to go to a training thing in San Antonio for a little while and just got back. I have everything done but finishing up the forks and doing the fluid changes. So last night I went to put the lower forks together and ran into a problem... 1st off, I forgot to run by Lowe's and get a piece of PVC to seat the fork seal with and then... this is the one that hurt me, I went to put the bolt in the bottom of the lower fork and when I went to tighten it down, the piece it screws into inside the fork started spinning! Now it is stuck and will not tighten or loosen, just spin. Seriously pissed off right now. I think an impact drill will ghelp, but unfortunately I do not have one. I gotta run by the stealership this afternoon to pick up that bushing and I am seriously considering just having them put the forks togeher and then me take it home... It has just been the biggest pain in the *** for me, and I do not know why! But we will see. I have a friend with an impact drill so I might just swing by there and do it... either way, I am pissed; I about threw the damn fork through the wall.
Impact drill?? Which bolt are you talking about? Gota pic?
  #6872
Old 05-05-2012, 09:23 AM
beasleyiv's Avatar
beasleyiv
beasleyiv is online now
Did you reuse the stock bottom allen bolt? The factory ones have some sealing crap on there that can make a mess of things going back in. The replacements don't seem to have that stuff on there. If you have a friend to help, maybe he can pull up hard on the slider while you try to back that allen bolt out. Holding up on the slider might put enough force on the damper rod to keep it from spinning.
If you 'were' reusing the stock allen bolts, get some new ones at the dealer along with some new drain bolts. They all have copper crush washers that might fail if reused.
  #6873
Old 05-06-2012, 05:02 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
If it makes you feel any better, I've been hearing a weird squeak in my front end for the past few days.. i know it's the front end because i've slowed down and hit a few bumps (like 5-10mph) and it happens on the front when i hit a bump..so im like ..wtf.. i found one of my heat shield clamps came un done, so i tightened that back up thinking maybe it was the clamp rubbing on the heatshield) and took it for a ride..same thing, noise is there (and obnoxious..the guys i was riding with yesterday heard it over my exhaust, over their exhausts, and over the wind in their ears).. okay, so i tear the headlight off, the plates around the headlight, and strip it down to just the tire and the forks and such (which meant lifting up the gas tank and doing all that bs just to get at the connection for the headlight)..check the pinch bolts and everything, all is well.. take it back out for a test ride..the noise is still frickin there.. and now that I had those plates around the headlight torn off i notice i've got fork oil coming out from the top of the forks (just my luck).. i know I don't have too much oil in there, since the manual calls for 13.4fl/oz and even with the RaceTech stuff i dropped in, i only put in about 13.. then with everything torn down I notice all my bolts are leaking on the forks (the drain bolts are leaking, and the bolts that hold the spring tubes to the lowers under the forks) are leaking.. so that explains why i'm getting **** all over my front exhaust pipe.. but now that i had them all ripped apart, i managed to use a press and fit the 1" spacer in to the spring tube (that i was supposed to use with the RaceTechs, but they said it wasn't necessary)..so that should drop my front end about an inch.. got that done, gonna go out and find those crush washers and replace all 4 of those in the morning, and the gasket/o-ring on the top of the forks tomorrow..then put it all back together and test it out again..and if that noise is still there, i'm going to kick someone in the nards.
tl;dr - my sunday wasn't very fun.
  #6874
Old 05-07-2012, 01:42 PM
Shooter198's Avatar
Shooter198
Shooter198 is offline
Just wondering if anyone has an opinion as I am a little torn?. I would like to get a LED tail light for my lo, not interested in the integrated though.
  #6875
Old 05-07-2012, 01:51 PM
td234's Avatar
td234
td234 is offline
Just went through this myself a couple of weeks ago. I DID want the integrated tail light so my specs were a little different. I LOVE the look without the turns signals hanging off the sides.
I narrowed it down to BadAssLights, D2Moto and Custom Dymanics. BadAssLights seemed too price for basically the same product. D2Moto seemed to cheap. So, I went with the middle of the road, Custom Dynamics, and am thrilled. The quality is great, service is good and the light is well built. I highly recommend CD.
  #6876
Old 05-07-2012, 03:01 PM
Shooter198's Avatar
Shooter198
Can't Remeber if I have been to CD's website, Do they have one that is not intergrated? That just don't seem safe to me, not bright enough and people may not notice them. Are they super bright?
  #6877
Old 05-07-2012, 03:18 PM
td234's Avatar
td234
td234 is offline
I find it pretty bright. I figure it is really just about 4 inches from the original location so not too much of a move. I believe they do have just tail lights.
  #6878
Old 05-07-2012, 03:51 PM
Shooter198's Avatar
Shooter198
Thanks for the info, nice looking ride. I now have the hogrida laydown license plate bracket too, love the look.
  #6879
Old 05-07-2012, 06:15 PM
Youngneg's Avatar
Youngneg
Youngneg is offline
Shooter.... Brightasslight... Are pricey but worth every penny, I have a BAL- ST3... I think it is ,the laid down smoked with plate light..... It has a lot of setting to it,including intensity,flashes...... Great taillight!
  #6880
Old 05-07-2012, 08:40 PM
Goatman44's Avatar
Goatman44
Goatman44 is offline
+ 1 on the Brightasslight.
http://brightasslights.com/
Quick Reply: Calling all FatBoy Lo Owners
