What Are the Differences Between MH90-21 & 90/90-21 Sizes
Old 04-09-2010, 03:25 PM
drspencer's Avatar
drspencer
drspencer is offline
Default What Are the Differences Between MH90-21 & 90/90-21 Sizes
I have a 2007 Softail Custom, stock tire size is MH90-21.
What are the differences between the NH90-21 and 90/90-21?
Thanks
Old 04-29-2010, 10:14 PM
terrapin88's Avatar
terrapin88
terrapin88 is offline
It's my understanding that the MH90 tire has a higher load rating than the 90/90. If you go to the manufacturers web site you should be able to find a chart listing their tires and weight ratings so you can confirm this for yourself.
Old 05-01-2010, 10:18 AM
mp's Avatar
mp
mp is offline
MH90 is the same thing as 80/90. MJ90 is equivalent to 90/90. MM90 is 100/90. Just a different way to show the size.
The first number in 90/90 means approximately 90 centimeters wide, section width (they do vary, though). The second 90 means the sidewall height, bead to pavement, is 90% of the section width. So a 90/90 tire would be approx 90cm wide and 81cm from pavement to tire bead.
Big Mule
09-06-2020 03:30 PM
Wrenchy
Wheels/Tires
03-17-2015 07:08 AM
Monkeymann_916
Wheels/Tires
05-20-2013 02:49 PM
DonN
01-12-2012 02:50 PM
fixxr
04-07-2009 06:13 PM
Quick Reply: What Are the Differences Between MH90-21 & 90/90-21 Sizes
