Filling Primary with new oil
Old 04-07-2010, 08:32 PM
DeneFXDWG's Avatar
DeneFXDWG
DeneFXDWG is offline
Default Filling Primary with new oil
Couple of questions:
I downloaded a manual I bought off eBay for my '08 FXDWG the other day and it states to fill with 32 ounces of lubricant. Now, I know there are many opinions as to what brand to use. Is this the lubricant choice that some say will help reduce the "clunk" of shifting gears or is it the gear oil choice in the tranny that helps with the dredded clunk?
The manual doesn't say how to check the level also, do you just pour exactly 32 ounces into the hole after you remove the primary cover please?
I used Mobile 1 20W-50 synthetic for the main motor so is this a reasonable choice for the primary also or is ATF better?
Old 04-07-2010, 08:36 PM
sgod1100's Avatar
sgod1100
sgod1100 is offline
I'm not sure about Mobil 1 20w-50, but I use Amsoil 20w-50. It doesn't have any friction modifiers in it which means that your clutch won't slip. If you use any oil with friction modifiers your clutch will most likely slip. All i do is pour 32 oz. in primary and be done with it. I wouldn't worry too much about the "clunk" because usually it goes away once the bike is warmed up
Old 04-07-2010, 08:41 PM
Derv's Avatar
Derv
Derv is offline
Take no notice of the weight or volume stated in your manual. Drain the old oil and refill until the level just reaches the bottom of the clutch plates and you're good to go,
As far as oil grades go, use a motorcycle specific oil. Some oils have friction modifiers that could cause your wet Harley clutch to slip. Prob best to use the HD specific oil unless you're prepared to research suitabe oil type / grades. At the moment I've got Rev Tech in mine but I wouldn't be adverse to using a m/cycle grade engine oil in the primary. I'd quote grade numbers at you but I think you use different ratings in the US than we do in the UK
Derv
P.S - never had a clunk prob on my Dyna, maybe I'm just lucky but my G/box is as smooth as silk
Old 04-07-2010, 09:39 PM
Lorance66's Avatar
Lorance66
Lorance66 is offline
yeah I just pour in a quart. It won't all go in on the kickstand though so I usually get my wife to hold it up while I put it all in and put the cover back on.
Old 04-07-2010, 09:44 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
I just dump a full quart in there. I leave the derby cover on and go through the inspection plate. As far as what you dump in? You won't have a problem with any conventional 10-40, 20-50 or ATF. Don't use synthetic with modifiers, and along those lines - synthetic won't help anyways...
PS - did you drain the tranny and dump a lube in there vs. the oil that was in there?
Old 04-07-2010, 09:48 PM
DeneFXDWG's Avatar
DeneFXDWG
Yes, I drained the tranny after a good run to warm it up around town. I used the Red Line 75W-140 even though it says not to but it's gear oil so I hope it'll be alright. Thanks for asking!!
Old 04-07-2010, 10:01 PM
Baeseman1's Avatar
Baeseman1
Redline 75-140? You won't get much better than that...
You should notice a smoother shift & quiter gearbox after these 'upgrades'...
Old 04-08-2010, 09:42 AM
DeneFXDWG's Avatar
DeneFXDWG
Thanks Bassman. I will now put the Mobile 1 20W-50 into the primary. Nobody has answered my question yet as to what makes the clunk when going in gear, that's the primary correct?
Old 04-08-2010, 12:28 PM
bakerm75's Avatar
bakerm75
bakerm75 is offline
The clunk is normal. its the big difference between American and foreign bikes.
American (harley davidson) transmissions have always had a little clunk sound to them especially when dropping down into first. this can vary depending on how warmed up the transmission is.
You can reduce it by using quality oil, but you can't change the transmission so the clunk will never go away.
Proper filling of the primary is to only fill up until you can see the oil hit the lip of the clutch. on my 03 this tends to be 2/3rds quart. over filing can cause clutch slipage
Also, when you can't buy harley or vtwin oil you need to buy the heavy weight oil for a diesel engine. 20-50 is diesel oil i believe. I don't know of anyone running it in there stock cars.
hope that answers your question on the "clunk"
Old 04-08-2010, 07:03 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is online now
Received 4,282 Likes on 2,349 Posts
A technique i've found that works to minimize the "clunk". Both on first start and any cold starts, on a carb bike pull in the clutch and wait about 15-30 seconds ( with the clutch in) then shift into first. On my 05 FXDLI I pull in the clutch, wait a little bit, blip the throttle and when the rpm's drop momentarily that's when I shift into first. The clutch plates tend to stick together when not used for a while, i.e. overnight or 4-5 months.
Quick Reply: Filling Primary with new oil
