Exhaust Heat Shields - where to buy?
Old 04-07-2010, 04:34 PM
BobandGeri's Avatar
BobandGeri
BobandGeri is offline
1st Gear
Default Exhaust Heat Shields - where to buy?
I screwed up and melted a piece of towel on the front exhaust and crossover tube heat shields today. :<
Found a thread with ideas on cleaning, but does anybody know where I can buy new heat shields? I found one site that listed the front and rear exhaust shields, but not the crossover tube.
This is for a 2002 Sportster XL1200C
Thanks in advance!
Old 04-07-2010, 05:22 PM
veritas.archangel's Avatar
veritas.archangel
veritas.archangel is offline
Are you talking about the factory heat shields?
Old 04-07-2010, 07:44 PM
BobandGeri's Avatar
BobandGeri
1st Gear
Yes - the factory shields.
Old 04-07-2010, 08:04 PM
veritas.archangel
Wow, probably HD itself. But for what they will probably charge, maybe it's time to upgrade.
Old 04-07-2010, 09:47 PM
BobandGeri's Avatar
BobandGeri
1st Gear
Maybe it is time - suggestions on an upgrade?
Old 04-08-2010, 08:13 AM
veritas.archangel
I, personally, like my Vance & Hines Short Shots. But there are a lot of threads on this. Check around.
Old 04-08-2010, 10:45 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
The cleaning tricks should work just fine, but if not, I just saw a bunch of complete replacement/take-offs OEM systems on Ebay for a couple hundred.....(headers, crossover, mufflers and sheilds)
Old 04-08-2010, 04:01 PM
Zimbob's Avatar
Zimbob
Zimbob is offline
Try easy off oven cleaner. Follow the directions and don't get it anywhere but on the exhaust, it WILL remove paint.
If you are looking to upgrade, Vance & hines, Thunderheadder, Bassani (my favorite), Rineheart, several others. Go to a local bike night and listen, talk to others and go from there.
Old 04-11-2010, 06:45 PM
BobandGeri's Avatar
BobandGeri
1st Gear
Thansk all - Easy off worked for all but one spot that I tired using a rubbing compound on :< Found what I needed on Ebay so will be good shortly. Glad we are learning on this bike before we buy a newer/bigger one!
Old 04-11-2010, 06:48 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Ask around in here and I'll bet someone has a set sitting around they will give you. I would if I had some extra stock heat shields.
TZG18FLTRU
03-16-2017 10:53 AM
sbeast
06-23-2014 05:25 PM
oricko
08-07-2013 09:35 PM
lateralus
05-30-2012 06:59 PM
buick455gs
Exhaust System Topics
02-27-2008 02:46 PM
Quick Reply: Exhaust Heat Shields - where to buy?
