Clutch Removal
Old 04-06-2010, 08:21 PM
pjweber's Avatar
pjweber
pjweber is offline
Unhappy Clutch Removal
Hello, its been a while...2006 1200C Sportster...My clutch went out so I started to remove just the clutch pack following the steps outlined in the service manual, when I got into it and removed the friction and steel plates I noticed the rivets on the spring plate fell apart and tore up my clutch basket so I need to replace the basket also. I am now trying to loosen the mainshaft nut but the whole clutch hub turns which also turns the rear wheel. How do I get enough torque to overcome this?
Thanks for any input you have!
Old 04-07-2010, 02:45 PM
ArtR's Avatar
ArtR
ArtR is offline
I would try to put a block of wood under the tire to lock it in place enought to loosen the nut.
Ride Safe
Art
Old 04-09-2010, 08:02 PM
Stefan's Avatar
Stefan
Stefan is offline
Use a primary drive locking tool (modified hockey puck looking thing) and use a air ratchet. The nut may be left handed. I don't remember if it is the engine or tranny that is left handed. Locking out the primary is required & air tools not 6' breaker bars.
Spanners39
VRSC Models
06-16-2018 09:06 AM
BenRK05
02-21-2014 06:33 PM
Justin327
11-11-2013 10:21 AM
sdguyman
01-15-2010 09:44 PM
tdroadking
09-01-2008 01:20 AM
Quick Reply: Clutch Removal
