Broken bolt inside clutch release cover...
Old 04-08-2010, 07:23 AM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
I thought maybe it was the side door. My Short Shots mtg. brkt. bolted to the side door. I would try an e-z out before taking anything apart.
Old 04-08-2010, 08:14 AM
Derv's Avatar
Derv
Derv is offline
Originally Posted by dsavi
On a closer look, I saw that the broken stud is on the transmission side door, not on the cover. Major removal and disassembly... I think I'll leave it alone, for now.
Thing is, it's got to be sorted sometime so why not do it now before it throws other problems up? Be careful with the extractors - use only as a very last resort, break one of those in there and you'll have major problems. Personally I never use the hateful things. Based on the assumption that if the bolt won't come out by other means and you end up having to re-drill and tap the hole, it's always easier to drill the broken bolt out rather than a snapped extractor. Just my opinion of course - others may differ!
Derv
Old 04-08-2010, 05:48 PM
sniper77's Avatar
sniper77
sniper77 is offline
Take it to the shop and have them address it for you. If you don't, a leak will develop and the possibility of water contamination is increased.
I've done five transmission leak repairs this week and I can tell ya it is much cheaper to get this fixed now than it will be if you wait till later.
Depending on what exhaust you have, some allow access to the side door without removal, you are looking at one (1) no exhaust removal, to two (2) including exhaust removal hours of labor, max.
Old 04-14-2010, 10:03 AM
dsavi's Avatar
dsavi
dsavi is offline
Default Transmission side door gasket: #35654-06?
For a 2008 Dyna FXD, thanks again!
Old 04-14-2010, 10:12 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Should be the same part#. Your dealer should be able to verify.
Old 04-14-2010, 10:16 AM
HOGRIDA_06's Avatar
HOGRIDA_06
The side door is connected to the gear set. You'll need to remove the primary to get it off.
XKHemi
05-27-2015 08:59 AM
badfl97
05-04-2012 08:57 AM
asparks25
12-20-2010 02:09 PM
Yachtman
10-05-2010 11:20 PM
bennenrkc
06-11-2010 09:03 AM
Quick Reply: Broken bolt inside clutch release cover...
