Labor Charge for Big Bore Kit Install
Old 04-01-2010, 04:51 PM
bagabond's Avatar
bagabond
bagabond is offline
Default Labor Charge for Big Bore Kit Install
What are typical labor charges at HD dealer for Big Bore Kit installs?
Old 04-01-2010, 05:22 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
$95.00 an hour.
Old 04-01-2010, 06:05 PM
CruzinLow's Avatar
CruzinLow
CruzinLow is offline
I had the 103 kit put in, along with new pipes, cams, valve springs, & clutch spring, all for just under a grand (labor costs). Mech told me it takes about 12 hours to complete...
Old 04-01-2010, 06:10 PM
slvr_bullit's Avatar
slvr_bullit
slvr_bullit is offline
Depends on where you live, but plan on at least a grand. More if you are in a higher cost region
Old 04-01-2010, 06:14 PM
harleydavis's Avatar
harleydavis
harleydavis is offline
A grand sounds about right.
Old 04-01-2010, 11:45 PM
oct1949's Avatar
oct1949
oct1949 is offline
last Feb,, winter special our dealer had the 103 kit, installed, 255cams, lifters. and free dyno for $1800....didn't check this past winter...
Old 04-02-2010, 12:25 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
i had mine done last week,1550 with tw37 andrews cams, labour was $1022.00 nz ,so that would be over $700.00us dollars i guess!maybe $800.00
Old 04-02-2010, 12:57 AM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
Shop that did my stage II 103 kit ran a "winter special" from November 09 through Feb 10. Price parts and labor was $2000, included stage II 103 kit with SE 255 cams, SE clutch spring, new lifters, SE Super Tuner, dyno before the build, break in on the dyno and tuning after the build. They also installed a D&D Boss Fatcat and SE stage I air filter with zippers' upgrade that I provided and added an SE oil cooler for the touring models and manual compression releases. Total out the door with the adds and added labor came to just under $2700. Figures out that I saved about $1600 compared to "list" price.
Bike before build made 68 hp and 84 tq, after build makes 92 hp and 106 tq. Very glad I took the plunge.
You may find it worth your while to ride the bike as is until the fall of the year unless pressing repairs prompt your question.
Old 04-02-2010, 02:44 AM
Rocker_C's Avatar
Rocker_C
Rocker_C is offline
I just did mine myself, it isn't that hard and it took 2 days. The local dealer said they would do it for $750. I put in the 103 SE kit with SE255 cams and SE Kompressor heads. I paid $1190 for the parts and $267 to have compression releases installed and a complete chrome bolt engine kit. I also installed a PC5 with auto tune. It's been raining so I haven't been able to ride it much and only have 44 miles on the build.
Attached Thumbnails Labor Charge for Big Bore Kit Install-img_0595.jpg   Labor Charge for Big Bore Kit Install-img_0590.jpg   Labor Charge for Big Bore Kit Install-img_0598.jpg
SKJOLD
Ironhead
05-10-2020 03:12 PM
cobalt07
Exhaust System Topics
11
10-30-2011 10:40 PM
02hdfatboy
06-19-2011 10:07 PM
scooty
02-09-2011 10:18 AM
ToyjoHa
06-07-2010 04:10 PM
Quick Reply: Labor Charge for Big Bore Kit Install
