Wide glide vs. Narrow glide???
Old 04-01-2010, 11:36 AM
zird00's Avatar
zird00
zird00 is offline
Default Wide glide vs. Narrow glide???
Can some one explain the difference to me? I know what a FXDWG is. But I do not understand the difference when referring to the front end of the Dyna breed. And where does the Fat Bob, that would be FXDF not the tank, fall in all of this?
It seems, and I may be wrong here, that there is a 49mm wide and a 49mm narrow front?
Old 04-01-2010, 11:42 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Yes, there is 49mm wide and narrow. The wide is only on the wide glide. The narrow I believe is on FXD and FXDL. Could be other models it's available on within the dyna line, I'm just not sure.
and it pertains to the actual width of the forks/trees.
Old 04-01-2010, 12:11 PM
8541hog's Avatar
8541hog
8541hog is offline
What SC said, plus the Wide Glide has more rake in the front end than any other Dyna model.
Old 04-01-2010, 12:23 PM
Evil_keeps_me_young's Avatar
Evil_keeps_me_young
Evil_keeps_me_young is offline
and it's sure a beautiful thing too...
Old 04-01-2010, 12:44 PM
bakerm75's Avatar
bakerm75
bakerm75 is offline
Agreed
Old 04-01-2010, 12:51 PM
jaqmes's Avatar
jaqmes
jaqmes is offline
the mid glide is about 8.5o ln. c to c of the tubes. and the wide glide is about 9.25 I believe the fatbob is a wideglide with a different rake. It's been so long since i've even seen a narrow glide I couldn't tell you the c to c .
Old 04-01-2010, 12:58 PM
Nick0915's Avatar
Nick0915
Nick0915 is offline
Having that longer rake makes for a wider wheelbase. The FXDWG has the 2nd largest wheelbase @ 68.3" that Harley makes. The Rocker C is the only Harley with a wider stance @ 69.2". Whereas the FXD's wheelbase is 64.2"
Old 04-01-2010, 01:07 PM
GasserNorm's Avatar
GasserNorm
GasserNorm is offline
Concerning the older Dynas had 39mm tubes in narrow(sportster) trees and the wideglide had 41mm tubes in the wide(softail) trees. The earlier low rider shared the same frame as the wideglide.
Old 04-01-2010, 01:12 PM
jaqmes's Avatar
jaqmes
jaqmes is offline
just went to he shop and found my old frontend off the shovel. the c to c on the 39mm narrow is 7.25in.
Old 04-01-2010, 01:32 PM
2007fxdc's Avatar
2007fxdc
2007fxdc is offline
I thought the non WG and FB front ends, 06 and up, were now considered mid-glides, not narrow glides. Narrow's would be the older models with smaller forks right?
Quick Reply: Wide glide vs. Narrow glide???
