Sporty Chews Up Shifter Drums!
Old 03-28-2010, 09:30 PM
THPSRIDER's Avatar
THPSRIDER
THPSRIDER is offline
Default Sporty Chews Up Shifter Drums!
I was wondering if anyone had any suggestions to this problem. I have torn the transmission out a few times now and replaced the shifter drum twice and shifter forks once. After installing the new drum it shifts like a dream, then after about 75-100 miles it starts downshifting hard. It then really becomes difficult to shift in general. The shifter drum begins to burr in the channels and the shifter forks then cannot slide on it. Has anyone run into this before and what should I look at? I was considering tearing it apart again, replacing bearings, and checking tolerances. If you have something specific to look for that would help. Thanks.
Old 07-07-2010, 12:55 PM
THPSRIDER's Avatar
THPSRIDER
Anybody have an idea?
Old 07-08-2010, 02:31 AM
parts eeter's Avatar
parts eeter
parts eeter is offline
Default mainshaft bearings
Sounds like a problem in the output shaft bearings or the primary shaft bearings. Replace them next time its apart and look for funky wear patterns on the gearsets indicating this. Use quality synthetic oil. Hope that helps.
Old 07-08-2010, 07:37 AM
Brett001's Avatar
Brett001
Brett001 is offline
This does not seem to be a problem for most bikes, so something is likely bent, or a bearing is worn out.
The only sure way to fix it is to check everything in the transmission.
Brett
hardheaded
01-28-2019 03:21 PM
Ben221
05-22-2017 05:58 AM
mkguitar
12-13-2016 07:07 AM
Ironkidzsled
Ironhead
07-14-2014 10:43 PM
Figstr
09-03-2008 05:59 AM
Quick Reply: Sporty Chews Up Shifter Drums!
